Author Topic: Where can I get a vintage style battery for my 1970 280sl?  (Read 1397 times)
eb@bluwil.com
  • USA, NY, Jericho
I am looking for a battery that looks like the original one with the screw caps for water even it they are just for the look. I have seen some in pictures of restored cars…???
Re: Where can I get a vintage style battery for my 1970 280sl?
« Reply #1 on: May 16, 2024, 11:52:56 »
Not certain that there is universal agreement on, or if one single battery was supplied for the entire production run of the Pagoda.
Bosch has a series of vintage batteries apparently, which may look the part, but I don’t know if these match what was delivered with the car—but they look right.
https://www.bosch-classic.com/de/en/products/range-of-spare-parts/batteries
There are a few antique car battery manufacturers left in the USA, mostly catering to batteries that were delivered with American cars in the 20th century. There are also manufacturers of covers for other batteries, such as these guys:
https://www.tartopper.com/
Those who are creating illusions for car shows sometimes take batteries that look the part, maybe add a topper to it, and or fabricate logos from the period and place on the battery.
« Last Edit: May 16, 2024, 12:01:55 by mdsalemi »
« Reply #2 on: May 16, 2024, 13:45:16 »
Bosch sell batteries looking vintage, but they are also the old type, according to their dealer, meaning, they are not service free. I did not want to have this type of battery as the modern ones are much safer.
So I created my own (picture) old looking battery. The sticker is in Technical Manual, I think.
If you use search function on the forum, you will find a lot of information on the question you asked and several ways to make the modern batterty look vintage.
« Reply #3 on: May 16, 2024, 14:04:48 »
Here are some 3-D parts for printing your own modifications to create a classic looking battery:
https://www.sl113.org/wiki/Restricted/3D-Printed-Parts
See this thread for instructions: https://www.sl113.org/forums/index.php?topic=31991.msg232040#msg232040
« Reply #4 on: May 16, 2024, 15:02:45 »
When my car was restored 1999 to 2000, we simply got a conventional battery to install. This is one with the caps that needs to be filled periodically. What you may forget about these is that when you are not looking and the hood is closed they can and do leak. What they leak is acid and it makes a mess. So several years later, when I was replacing the radiator, I took some of the sheet metal parts out for powder coating and there was a lot of acid damage underneath the battery.
For me, a sealed battery is the only way to go today. There is too much value in the engine bay to suffer any acid damage. If someone wants to make it look like an old battery that’s great. I still would use sealed.
« Reply #5 on: May 16, 2024, 15:16:06 »
Yes, Michael expressed exactly what I tried to put in much too condensed form probably, thank you.
I found the Bosch catalogue, but, as I said, I walked away.
« Last Edit: May 16, 2024, 15:20:19 by Pawel66 »
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
« Reply #6 on: May 16, 2024, 17:17:32 »
Layman question: what color were then Varta batteries
 installed in 230sl's in 1965?  white or black?
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
« Reply #7 on: May 16, 2024, 21:24:41 »
This is the only image I have at hand.
Never seen them white, but it does not mean anything. The material used those days for battery fabrication was not the type of plastic we have today. It was black by nature. I doubt there were white batteries those days, but I cannot be sure.
If you Google "varta vintage battery" and go to images - there are plenty of them, black.
Then I found this site and looked through history - in 1966 the type of material box was made of changed. Not sure about the color.
https://www.varta-automotive.com/en-gb/why-varta/varta-brand-history/1960-1979
« Last Edit: May 16, 2024, 21:47:49 by Pawel66 »
john.mancini
  • USA, FL, Nokomis
« Reply #8 on: May 17, 2024, 13:06:13 »
Try batterycentralmall.com.  They have repro 24 series batteries for MB and other European cars from the 50's and 60's. I've had one in my 65 230Sl for 4 years and it's been great.
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
