Author Topic: Door Ajar Light  (Read 1134 times)
acbrock
  • USA, CA, Santa Monica
Door Ajar Light
« on: May 23, 2024, 19:52:50 »
Am I reading the tech manual correctly about the door ajar light on 230's?  Reading about other things I am working on I keep see the the door ajar light does not apply to 230's?  is that right that it is not active on a 230?
1966 230SL Automatic 717G Papyrus White "Minny"
DavidAPease
  • USA, CA, Chico
Re: Door Ajar Light
« Reply #1 on: May 23, 2024, 21:11:36 »
There is no door ajar indicator on a 230sl.
            - David
-David Pease
acbrock
Re: Door Ajar Light
« Reply #2 on: May 23, 2024, 21:22:54 »
Cool.  But the under dash light should come on correct?  Obviously mine does not.  The light works but not to the doors.  Want to chase that wire before I wrap all my wires up again.
DavidAPease
  • USA, CA, Chico
Re: Door Ajar Light
« Reply #3 on: May 23, 2024, 22:07:43 »
Yes.  I have a '66 as well, and (with the switch in the correct position) the under-dash light comes on when either door is opened.
           -David
-David Pease
Re: Door Ajar Light
« Reply #4 on: May 23, 2024, 23:38:33 »
Does light come on when you move the switch to position 1?
https://www.sl113.org/wiki/Electrical/CabinLight
acbrock
Re: Door Ajar Light
« Reply #5 on: May 24, 2024, 15:34:55 »
Yea Position 1 Works.   I am going to play with it today while I try and figure out the wiring on my Fuel Sender.
