Please check out joining the
Emergency Contact List
for help during your travels!
General Discussion
Need to replace my FSVT?
Topic: Need to replace my FSVT? (Read 1274 times)
dldubois
Full Member
Silver
USA, FL, Pembroke Pines
May 26, 2024, 21:12:25 »
Here's a pic of underneath my car. Noticed the last few times I was driving around I'm then dripping gas. Used to have the FSVT underneath but noticed now its gone....
I have had people working on it.
What's the replacement solution? Couldn't find any in reviewing the fuel venting topics. Here's a pic of where it must've broken off and where I'm leaking gas once I've been out driving around. Guessing its been bent and broke off. Looking for solution of part to use to replace and how to address.
Thanks much!
Dana DuBois
1969 280sl
Pembroke Pines, FL
jKrashnburn
Associate Member
Junior Level
Canada, Alberta, Edmonton
Re: Need to replace my FSVT?
May 26, 2024, 23:20:56 »
Pardon my ignorance but I'm a Newbie around here.........What's a FSVT?
John
1957 190SL 8500074 (RIP?)
1968 280SL 11304410006390 (RIP?)
1969 280SL 113044120011428 - Light Beige/Cognac
kampala
Full Member
Platinum
USA, CA, Beach Cities
Reply #2 on:
May 27, 2024, 02:21:40 »
Dana,
https://www.mbclassics.de/Manschette-Tankentlueftung-110-111-112-113
250sl - later - manual
280sl - 1971 - Auto - LSD
Full Member
Platinum
USA, CA, Fallbrook
Reply #3 on:
May 27, 2024, 03:00:54 »
FSVT = Funnel Shaped Vent Thingy
I believe you have a more serious issue than just missing the FSVT, I don't believe that prevents fuel leaking, so I think there's another cause for that that you need to investigate. Maybe a clogged vapor canister.
jKrashnburn
Associate Member
Junior Level
Reply #4 on:
May 27, 2024, 15:44:00 »
Aslam/Cees......many thanks for the clarification!
John
John
dldubois
Full Member
Silver
Reply #5 on:
May 27, 2024, 19:28:37 »
Cees, I know it used to be there and haven't ever had an issue. Not leaking much. Just some out of that hole once I've zipped around a bit. Haven't noticed it at all on the fuel gauge.
Just noticed some drips here and there.
Does the FSVT just attach with a hose? Looks like it just was bent off?
Seems like a good start is replacing? Then go from there.
Dana DuBois
1969 280sl
Pembroke Pines, FL
Charles 230SL
Full Member
Gold
USA, GA, Griffin
64 230SL
Reply #6 on:
May 27, 2024, 20:48:02 »
hello Dana, I needed one a few years ago and bought it from Authentic Classics:
https://www.authenticclassics.com/Mercedes-Fuel-Evaporation-Canister-Vent-Boot-p/auth-007111.htm
It's held in place with a Norma clamp:
https://www.authenticclassics.com/Mini-Screw-type-Hose-Clamp-Norma-8-10mm-size-p/auth-004309.htm
dldubois
Full Member
Silver
Reply #7 on:
May 29, 2024, 19:11:07 »
Thanks, leaking some so guessing I should just replace the whole vapor / venting set up. Pretty reasonable.
Dana DuBois
1969 280sl
Pembroke Pines, FL
Full Member
Platinum
USA, CA, Fallbrook
Reply #8 on:
May 29, 2024, 23:52:15 »
I think it's best; you really don't want any fuel leaks, it's an indication something is wrong - and it could get worse! Fires start this way.
General Discussion
