Author Topic: Order for Rear Axel Install  (Read 712 times)
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
« on: May 27, 2024, 22:59:43 »
The rebuilt rear axel is now hanging in the car.  A year behind schedule but it good be working on the car again.  Based on your past experience, would you install the differential cross strut or the rear control arm?
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
dirkbalter
  • USA, CA, Corona
Re: Order for Rear Axel Install
« Reply #1 on: May 28, 2024, 15:25:34 »
What exactly are you asking?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
merrill
« Reply #2 on: May 29, 2024, 18:37:48 »
Alex
if you are re installing the axle,  i believe the below are the steps i followed when re installing mine
1. with swing arm spring installed, lift axle at 3 points,  diff, left and right side until you can secure the diff hanger.
2. then cross locating strut
3. then left trailing arm
4. then right trailing arm
5. once all is in place then deal with trailing arm springs.
the whole time making sure the spring did not come out of its perches
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
afibbe
  • 513-374-5600
« Reply #3 on: May 31, 2024, 01:38:47 »
Thank you.  That is exactly information I was looking for.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
