Hi Guys , i've been having my clock not working for more than 10 years , now it's time to repair. Do you have some video procedure on how to remove and put back again ? i read that you need to remove the glove box first . The most challenging part is to re align the glove box once again . Any suggestion would be helpful. Mine is the original one and suddenly stopped working about 10 years ago. The light bulb is also not working. I would prefer to keep originality and not put the quartz movement . Since i disconnect the battery when i do not use the car , the clock will be not working with no power , is this process dangerous for the clock itself ? Thank you
