Author Topic: Clock Disassembly  (Read 2580 times)
Harry
  • USA, TN, Knoxville
Clock Disassembly
« on: June 16, 2024, 21:03:05 »
1966 230SL.
Has anyone removed the white cover off of the back of the clock?  There are two tiny nuts, and a round puck like object that appeared to be holding the cover on.  When I removed those, the plastic cover could be removed only to a point.  The three pins for ground, light power and clock power slid nicely through the casing so they were not the issue.  But it appears there is a brown wire that may be thing that is restraining removal.  I'm reluctant to try more firmly to remove the cover since it seems something is clearly restraining doing so.
Thank you,
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
WRe
Re: Clock Disassembly
« Reply #1 on: June 17, 2024, 05:03:49 »
« Last Edit: June 17, 2024, 05:11:04 by WRe »
BobH
« Reply #2 on: June 17, 2024, 10:23:55 »
There are a few videos on line which may help, although this one already has the cover off, so shouldn't be too difficult
https://www.bing.com/videos/riverview/relatedvideo?q=mercedes+w113+vdo+clock+repair&mid=FB4FD6AF37BBE0A516CCFB4FD6AF37BBE0A516CC&FORM=VIRE
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #3 on: June 17, 2024, 11:19:53 »
It is the brown ground wire that makes it difficult to remove the white housing. You need to tilt it towards where the wire holds it, like shown on one of the pictures.
Do not place the clock on its face while working on it or you will break away the adjuster knob and/or the transparent collar around it. Then you will have to fabricate new "glass", which is possible but takes some time and effort.
Harry
« Reply #4 on: June 18, 2024, 20:45:29 »
Thanks everyone!  What a forum!!
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
