Author Topic: RHD wiring harness routing  (Read 1497 times)
WhiteBlue
  • Australia
« on: June 17, 2024, 09:53:50 »
Can anyone tell me if the wiring harness sits above or below the clutch / brake pedal assembly on a RHD 280 SL ? Thank you Mike
Mike WhiteBlue
Duncan200
  • Just started my Restoration
Re: RHD wiring harness routing
« Reply #1 on: June 17, 2024, 12:17:45 »
Hi Mike,
I’ll take some pics and post them up for you tomorrow.
Doug
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day it will be back on the road in all its glory.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Duncan200
« Reply #2 on: June 18, 2024, 04:37:10 »
Hi Mike,
Both the loom from the fuse box and the grommet that goes through the firewall sit above the pedal box.
Except when it runs along the bottom ledge of the dash where the back of the pedal box bolts up, it goes underneath it.
Really hard to get a photo of it through the tacho hole as there is so much going on in there. If you need a pic, I’ll try and take one.
Hope these help, if not let me know?
Doug
WhiteBlue
  • Australia
« Reply #3 on: June 18, 2024, 05:52:27 »
Doug that’s a great help. Thank you ! Mike
Mike WhiteBlue
