Author Topic: Mechanic Reference  (Read 1121 times)
Camhi
  • USA, NY, Long Island
Mechanic Reference
« on: June 18, 2024, 00:35:05 »
Hey all, located in Nassau County, Long Island. Looking for a reference(s) for a mechanic. Currently need to install new shift lever bushings, potentially a whole new shifter.
Tia
Jordan
  • Canada, ON, Jordan
Re: Mechanic Reference
« Reply #1 on: June 18, 2024, 10:47:20 »
Tia, I can't help you with a mechanic but if you are even a little mechanically inclined you can probably change the bushings yourself.  It's one of the first things I did when I purchased my car 15 years ago.  It's been written up here to help you through the process.  Just do a search.  Biggest obstacle may be getting your carpet off the tunnel cover if it was glued down.  Hopefully it wasn't.
Marcus
66 230SL  Euro 4 speed
merrill
« Reply #2 on: June 18, 2024, 12:28:16 »
Tia
assuming the car is an automatic replacing the shift bushings is very easy.
bushings are readily available at many sources.  I usually buy extra and keep them in the trunk.
if you need instructions you can message me.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Camhi
« Reply #3 on: June 25, 2024, 14:51:08 »
Thanks! Was able to replace and yes the glued down interior made things tougher lol
Jordan
« Reply #4 on: June 25, 2024, 16:07:27 »
Glad to hear it worked out and you got it done.  The carpet over the tunnel does not need to be glued down so hopefully you didn't reglue it.
Marcus
