Author Topic: TM : small but important error in Valve adjustment tour  (Read 754 times)
rosch
  • Netherlands, Gelderland, Halle
Discovered an small mistake  in the TM "Valve adjustment tour"
@ Tools needed it says :
5.Feeler gauges: 0.8 mm (0.003 inch) and 0.20 mm (0.008 inch) thick, 10 mm wide.
It should read:
5.Feeler gauges: 0.08 mm (0.003 inch) and 0.20 mm (0.008 inch) thick, 10 mm wide.
Hopefully nobody used the wrong feeler blade  for the intake valve adjustment !
Re: TM : small but important error in Valve adjustment tour
« Reply #1 on: June 24, 2024, 20:53:20 »
You realise that you can fix such an error! Have a go and contribute!
rosch
« Reply #2 on: June 24, 2024, 21:03:07 »
Just figured out how easy it is to use the "EDIT" function.Must have overlooked it due to inexperience. Thank you !
« Reply #3 on: June 24, 2024, 21:06:25 »
Well done! Let that be an inspiration to other contributors!
