Author Topic: Alternator upgrade  (Read 1472 times)
gordon
  • United Kingdom, England, Burntwood
Alternator upgrade
« on: July 09, 2024, 09:40:22 »
I am having trouble finding  a Bosch AL72 alternator here in the UK.  I believe that my 35amp is Bosch number 0120400532, is there an equivalent number for the al72x.
Was the al72x fitted to later Mercs, if so which ones, maybe I can get one from a salvage yard.
lpeterssen
  • USA, FL, Miami
Re: Alternator upgrade
« Reply #1 on: July 10, 2024, 11:10:55 »
Dear Mr. Gordon
I have checked the specs and photos of that Bosch AL72X alternator on various sites and Imthink it will work perfectly for your pagoda as a substitute for the older AL72.
This AL72X is for external regulation, as your original one.  Make sure to install a new voltage regulator at the same time as a precaution.
You may have some changes at the kind of connector for the external voltage regulator, but the number of leads is the same as well as cable names.  So for a good electricians that will be no challenge.
For the voltage regulator go for the BERU which is reasonable priced. (50 $ max)
Best regards
Eng. Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
Links for matching voltage regulator
« Reply #2 on: July 10, 2024, 11:27:42 »
Dear Mr. gordon
Here some useful links for the voltage regulator.
At SLSSHOP FOR 30 EUR
https://parts.theslshop.com/mercedes-benz-1965-74-alternator-voltage-regulator-beru-0021547406/. 30 EUR
AT AMAZON for 65$
Beru AG GER024 Alternators https://a.co/d/0bqy05O1
Best regards
Lp
Www.wiredoktor.com
RAY
  • United Kingdom, England, Bromley
« Reply #3 on: July 10, 2024, 17:24:58 »
Is there anything that Amazon doesn't sell these days, seems not ! !
gordon
« Reply #4 on: July 10, 2024, 17:33:53 »
Thankyou Leo for your response. I would like to avoid the customs and freight costs of importing from the US into the UK hence my question, was the 55amp alternator fitted to later Mercedes? If I new the Bosch part number for the 55amp alternator that would be a great step forward.
Further help would be appreciated . Thankyou Gordon
dirkbalter
  • USA, CA, Corona
« Reply #5 on: July 10, 2024, 17:50:13 »
Yes, they were. Also a lot written about it here if you search.
Why do you think you need a 55 amp one?
https://www.pelicanparts.com/More_Info/005154740288.htm?pn=005-154-74-02-88-M14&bc=c&SVSVSI=
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
gordon
« Reply #6 on: July 11, 2024, 09:35:18 »
Thanks, the Pelican list is great in listing Mercs with similar alternators. Reason for upgrading is 35 amps doesn’t seem to give much margin if driving with lights, wipers, fan, music etc on and I might fit an electric radiator fan at a later date
