Author Topic: Pics with modern tires?  (Read 2093 times)
Ahealey12
  • USA, TX, San Antonio
« on: July 16, 2024, 02:50:17 »
On the look out for some cheap tires. Looking at it i currently have some white wall classics 205/70/14 and really don’t see many people running more modern tires, does anyone have any pics with more modern? Is there a reason people use the classic tread design?
Also is 195/70/14 that bad for the speedo reading? Seeing they are much cheaper
1967 230sl auto
1967 Chevelle ls swap
1968 bronco ls swap project
2022 zl1 Camaro
2021 Range Rover velar daily family car
DavidAPease
  • USA, CA, Chico
Re: Pics with modern tires?
« Reply #1 on: July 16, 2024, 03:43:38 »
How cheap?  I have a set of Hankook Kinergy ST in size 195/75 R14.  (Mine are blackwalls, which I prefer the look of on my Euro 230SL.)  They are $85 per tire at America's Tire (where I bought mine).
An early (very knowledgeable) member of our online group, Arthur J. Dalton, once did the calculations for which modern standard tire size most closely matched the original aspect ratio of our cars, and came up with 195/75; I have used that size ever since, and believe my speedometer is pretty accurate.
There's a photo of my car with these tires here (you can click on the photo and get a pretty good look at the tires):
https://www.sl113.org/forums/index.php?topic=37189.msg272238#msg272238
           -David
-David Pease
WRe
« Reply #2 on: July 16, 2024, 06:34:17 »
Last year I decided on the Falken tires in size 195/70 R14 91H (for aluminum rims) and I haven't regretted it to this day because the tire rides a lot better than the original Vredestein in size 185/80 R14. The price back then was <80€/piece, half of Vredestein. The speedometer now shows 3.5% more.
...WRe
« Last Edit: July 16, 2024, 14:44:14 by WRe »
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #3 on: July 16, 2024, 12:36:51 »
Ahealey12, lots of members want to keep the classic look, and not the look of a muscle car.
Robert Hyatt
Williamsburg, VA.
« Reply #4 on: July 16, 2024, 14:56:10 »
Plenty of cheap tires around, if that's what you want. If you want cheap, don't pay too much attention to the exact size, as you may not find it.
My own opinion is that with just four small contact patches between you and the road, the last thing I want is cheap tires. It seems much of my Pagoda driving has been motorway/interstate/highway at 4000 rpm, 60-75 MPH. I want a good tire not a cheap one.
I had the Coker's for years, and two years ago changed to the Blockleys. They may still offer a discount for our members here, ask for it...but they are not cheap tires by any means.
Ahealey12
« Reply #5 on: July 16, 2024, 16:51:24 »
I guess I’m not meaning desperately cheap still name brand but more so a modern tread pattern. They are cheaper than the classic pattern ones.
1967 230sl auto
2022 zl1 Camaro
Ahealey12
« Reply #6 on: July 16, 2024, 16:52:39 »
Thank you! Definitely shows what I’m looking for. I would much rather be safer on new design and yes they are cheaper but only could find photos with older design.
1967 230sl auto
2022 zl1 Camaro
  • USA, WI, Mequon
« Reply #7 on: July 16, 2024, 21:32:09 »
I've been happy with General Altimax RT43 205/70-14
« Reply #8 on: July 16, 2024, 22:03:44 »
Discontinued and replaced with the RT45. "Program of continual improvement..."  ;)
WRe
« Reply #9 on: July 18, 2024, 06:39:28 »
here you can find a test of summer tires and find good and bad ones:
https://www.adac.de/rund-ums-fahrzeug/ausstattung-technik-zubehoer/reifen/reifentest/sommerreifen/205-55-r16/
...WRe
« Reply #10 on: July 18, 2024, 11:15:57 »
...WRe
Thanks for posting however probably not much help for the American who asked the question (unless he can read German). Further I don’t think all the tires tested are available in USA, nor available in an appropriate size for a Pagoda. The tires tested were all 205/55 R16.
One may, for example, find it difficult to get Minerva or Tomket tires in the USA.
« Last Edit: July 18, 2024, 11:27:41 by mdsalemi »
Benz280
  • USA, NJ, Jersey City
« Reply #11 on: July 18, 2024, 13:21:41 »
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
WRe
« Reply #12 on: July 18, 2024, 13:38:54 »
Hi Benz280,
Your tire choice wouldn't be allowed on our cars here in Germany because of a too low speed rating (T=190km). H=210km would be obligatory.
...WRe
zak
  • USA, NJ, Bernardsville
« Reply #13 on: July 18, 2024, 19:49:58 »
Then there is always the question of tire size. John's red beauty looks great with the 205/70/14s.
I bought 195/70s 6 years ago. When I buy new tires I will go to 207/70s. More rubber underneath and a larger circumference that will lower RPM's a bit too.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
john.mancini
  • USA, FL, Nokomis
« Reply #14 on: July 21, 2024, 01:40:27 »
Hankook white walls. I’ve had them for 4 years. Very good tires and they look period correct.
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
Lenosa
« Reply #15 on: September 12, 2024, 17:56:13 »
I recently swapped out my old white walls for some modern tires and the difference in handling was noticeable. The classic tread design definitely has a vintage appeal, but newer tires usually offer better grip and safety. As for the speedo, switching from 205/70/14 to 195/70/14 doesn’t make a huge difference, but it might slightly throw off the reading. I went with the cheaper 195s and haven’t had any major issues.
