Author Topic: How bad i mess up distributor?  (Read 1007 times)
Ahealey12
  • USA, TX, San Antonio
« on: July 16, 2024, 05:30:56 »
Was trying to get pints out and the other side snapped. Had a ball and other parts come out while trying to start pertronix install.
Am i screwed? Or do i even need the vacuum advance? The instructions are terrible.
Circled broken parts on one pic.
1967 230sl auto
1967 Chevelle ls swap
1968 bronco ls swap project
2022 zl1 Camaro
2021 Range Rover velar daily family car
Re: How bad i mess up distributor?
« Reply #1 on: July 16, 2024, 13:04:20 »
You definitely want the advance! Car will be very sluggish without.
If you can't put the thing back together, I do suggest you return the Pertronix and get a new 123 ignition, that will replace your entire distributor and it really works. No worrying whether your distributor shaft bearings are worn, or the flyweights / springs are working properly, dwell, and so on.
1972 Lancia Fulvia Coupe 1.3
Bshaunessy
  • Canada, British Columbia, Invermere
  • 1957 190 SL; 1970 280 SL; 1975 450 SL; 1971 300 SE
« Reply #2 on: July 16, 2024, 14:45:54 »
I second the recommend to forget the PERTRONIX ( somewhat dated tech and a bit finicky) for a period correct looking 123 distributor.   Once installed, you will likely never have to fiddle with it again.
   Research 123 distributor on this forum….lots of positives.
Ahealey12
« Reply #3 on: July 16, 2024, 16:01:13 »
Thank you both. I was originally planning on the 123 but then decided to try to give this a go. Looks like 123 it is. With the 123 do i have to order the pinch clamp too?
1967 230sl auto
2022 zl1 Camaro
Ahealey12
« Reply #4 on: July 16, 2024, 16:55:22 »
Scratch that found on the forum. From mbzse adding here if anyone needs. Just ordered the 123 :)
1967 230sl auto
2022 zl1 Camaro
