Author Topic: Points replacement with Pertronix electronic ignition 71 280  (Read 1208 times)
nmasadeh
  • USA, OH, Cincinnati
i have a 71 280 with the transistorized unit and 062 distributor. I asked Pertronix if they have electronic ignition for this unit. They recommended 1863 conversion kit. But from reading here my understanding is that this will not work with the later model 280. Anyone had any luck replacing points system with Pertronix? if so, which model. Thanks
clunker
  • USA, NJ, Chatham
Re: Points replacement with Pertronix electronic ignition 71 280
« Reply #1 on: August 24, 2024, 14:46:59 »
See no responses here, but my 2c is that the 123ignition is probably a preferred option - you can put the original ignition set up in storage in case 'originality' ever comes calling. The 123ignition looks basically the same as original and will rejuvenate the engine performance with substantially more reliable and controllable ignition timing.
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
« Reply #2 on: August 24, 2024, 15:20:11 »
And immobilizer. Also a gauge panel with RPM, speed, Volts, Amps, crankshaft advance and MAP.
