Author Topic: Rear Spring Paint Mark/Dot Decoder - 3 red, 3 yellow (280SL)  (Read 499 times)
esilva
  • USA, CA, Palo Alto
hello,
can anyone tell me what thickness spring pad (upper)  I need if my rear springs (280SL)  are marked with 3 yellow paint stripes and 3 red paint stripes?  I've searched for paint marking decoder ring but cannot find one.  I've read that the decoder is in the BBB, but I do not have that book.  The part # is unreadable on  the old spring pads that I have removed.  I know there are 3 options 18mm, 24mm, 30mm for the upper spring pads on the rear springs.
Another question: does the mounting of the lower spring pad plate indicate the upper spring pad thickness.  I understand there are 3 ways to install spring pad plate.  But what is the translation of the mounting to the 3 thickness options?
There are many postings on spring paint markings but no decoder to be found.
My car is 1969 280SL, manual, power steering, no AC.
thanks much
'69 280 SL
