Please check out joining the
Emergency Contact List
for help during your travels!
Plastiguage- correct tolerance?
Topic: Plastiguage- correct tolerance? (Read 620 times)
jzearfoss
Full Member
Junior Level
USA, MT, Libby
July 20, 2024, 18:28:54 »
Reassembling my 280 SL block and cannot seem to find what the tolerance(s) should be for the main bearings and rod bearings when fully torqued to spec. Would appreciate any help finding that info.
1968 280 SL (AT)
2000 BMW Z3
1962 Pontiac Grand Prix
1951 Studebaker Commander
1937 Plymouth.
Charles 230SL
Full Member
Gold
USA, GA, Griffin
64 230SL
Re: Plastiguage- correct tolerance?
July 21, 2024, 21:24:37 »
hello JZ, tolerances for the main and rod bearings when fully torqued are located here:
https://www.sl113.org/wiki/Engine/Start?action=download&upname=MBEngineSpecs.pdf
The table at the bottom of page 5-266 shows clearance specs for the main bearings and connecting rod bearings. respectfully,, Charles
jzearfoss
Full Member
Junior Level
USA, MT, Libby
Reply #2 on:
July 22, 2024, 14:24:51 »
Thank you Charles. After getting this reply from you I revisited the Engine section in the Technical Manual and see the link there at the very top of the page. I see my mistake now. Greatly appreciate your help. jz
1968 280 SL (AT)
2000 BMW Z3
1937 Plymouth.
