Author Topic: engine ovrerhaul  (Read 890 times)
steves sl
  • USA, WI, CEDARBURG
engine ovrerhaul
« on: July 22, 2024, 00:49:58 »
I finally received my 83mm piston, for my 127 engine. Purchased 6 additional Ring sets and Crank and Rod Bearings all Mercedes Parts so I should not have any fitment issues. The plan is to lightly Hone the Cylinders, since there is No ridge, and replace the new parts. My Brother and I have done several small block Chevrolet engines. The engine is disassembled down to the short block. Is there anything in particular that we should pay attention to on a 127 Mercedes engine?
S. Schlaefer
Re: engine ovrerhaul
« Reply #1 on: July 22, 2024, 05:02:54 »
If you have the crank shaft ground, be sure to supply the machine shop with the thrust main bearing, so they can set up the thrust clearance correctly.
Pinder
  • USA, NJ, Edison
« Reply #2 on: July 23, 2024, 15:19:25 »
make sure you use thread sealer on any studs that go into the head. Some water passages may have studs that go into them.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
ctaylor738
  • USA, VA, Falls Church
« Reply #3 on: July 24, 2024, 17:31:56 »
Be sure all the oil galley plugs are in place (don't ask me how I know).
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
