Author Topic: W113 DOOR clips  (Read 2975 times)
Savakis
  • Greece, Central Macedonia, THESSALONIKI
W113 DOOR clips
« on: July 22, 2024, 19:05:47 »
HELLO,
Can anybody identify the metal and white plastic door clips as seen in the attached photos ?
I am wondering how to use them...
In addition, where exactly should I use the rubber ends of the second picture ?
BobH
Re: W113 DOOR clips
« Reply #1 on: July 23, 2024, 16:21:13 »
Hello, have a look on here, and also look at the other links contained within the post, should tell you what you need
https://www.sl113.org/forums/index.php?topic=28565.msg206350#msg206350
Are these the rubber stops, can't quite see from your pictures, but they look similar
https://www.authenticclassics.com/Left-Top-Pillar-Seal-Mercedes-230SL-250SL-280SL-p/auth-007145.htm
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
