Author Topic: 4 Speed gear box removal reseal and anything else needing replacement  (Read 8961 times)
Pinder
  • USA, NJ, Edison
Re: 4 Speed gear box removal reseal and anything else needing replacement
« Reply #50 on: September 25, 2024, 18:17:37 »
I finally put everything back together and re  installed the gearbox. I had to disconnect the drive shaft from the diff in order to be able to re install it. First short drive went well, no issues noted. It was a little tricky to lift the box in place using a regular floor jack.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
BobH
« Reply #51 on: September 25, 2024, 18:22:54 »
Hello Pinder, well done!  i've thoroughly enjoyed reading this post, so glad to see such a good result
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Pinder
  • USA, NJ, Edison
« Reply #52 on: September 25, 2024, 19:45:44 »
Thanks Bob.
I could not have done it without the expert advice I received along the way.
I made a few mistakes along the way but was able to correct and proceed foreword.
Along the journey I took the opportunity to bead blast the aluminum parts and paint the cast iron box and polish up the shifter rods and protect them with some clear coat. I also reviewed the shifter bushings even they I had replaced before as they are cheap.
In addition to resolving the gearbox leak it feels good knowing I replaced the broken shaft key and replaced the seals.
It really looks clean under the car now . My next improvement to the car is replacing the exhaust system from time valve. I put my order in but there is a few weeks delay before they can start making my exhaust system.
I’ve enjoyed working on this gearbox project.
Pinder
  • USA, NJ, Edison
« Reply #53 on: September 25, 2024, 19:50:28 »
Picture of gearbox with shifter installed to test out ability to shift into all gears.
I also prefilled the gearbox before installing it into the car to save the hassle of using the fill hole.
Also I tested the 2 switches worked (that continuity works when they are engaged.
Pinder
  • USA, NJ, Edison
« Reply #54 on: September 27, 2024, 14:51:54 »
took the car out last night for a 30 min drive and drive it hard. shifted great. This morning I inspected for any kind of leaks and happy to report zero leaks. For the first time in 9 years, I have an oil free garage floor. My two main leaks were from the power steering Box and the gearbox. Both now resolved.
« Reply #55 on: September 29, 2024, 04:03:42 »
Chasing leaks on an old vintage car can be frustrating and expensive. Eventually new ones or the old ones can return over time. Hopefully not for a long time!! Great Job!
