Author Topic: Will not go into reverse (automatic)  (Read 1201 times)
Pagodatastic
« on: July 26, 2024, 10:33:53 »
Fellow Pagodaites,
Some advice required please.
My SL280 1969 US Model will not go into reverse.  Forward gears all fine but stays in neutral when I put the gear shift into the reverse position and does not engage.
I fear this problem is beyond my limited mechanical skills but any advice very welcome.
Thank you
Best
Steve
BobH
Re: Will not go into reverse (automatic)
« Reply #1 on: July 26, 2024, 17:51:44 »
Hello, hopefully it's just the nylon bushes, perhaps there's an epidemic of bush failures in the UK at the moment, as Brennie also has a problem, see here
https://www.sl113.org/forums/index.php?topic=38415.0
I think it's easy enough to check, and not that difficult to replace the bushes if they are the problem
If it's not the bushes, there's the same problem on these posts, reverse band adjustment
https://www.sl113.org/forums/index.php?topic=26649.msg190658#msg190658
https://www.sl113.org/forums/index.php?topic=25886.msg185386#msg185386
« Last Edit: July 26, 2024, 19:17:25 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #2 on: July 27, 2024, 04:54:09 »
There is a reverse band adjustment on the right side of the automatic transmission, near the pan and close to the bell housing. It comes loose sometimes and causes exactly the problem you describe. Identify it as a 10mm (wrench size) hex head with a 22mm lock nut around it. To adjust it. loosen the lock nut and turn the 10mm hex head in until it becomes just snug, then back it off one and three quarter  (1 3/4) turns. Then tighten the 22mm lock nut. There is a nice picture of mine on this site somewhere which shows the adjustment. i'll try to find it and will post it. Make sure your fluid level is good before you begin. Check while running on flat ground with engine warm. It is one pint between the marks on the dip stick.
Pagodatastic
« Reply #3 on: July 28, 2024, 11:45:03 »
Thank you so much.
Pagodatastic
« Reply #4 on: July 28, 2024, 11:45:58 »
merrill
« Reply #5 on: July 29, 2024, 14:26:07 »
i had the same issue on my 78 300d.
would not reverse,  adjusted the reverse bank and all is well
also check your trans fluid
another point is if the car has been sitting you need to allow time for the fluid to circulate and build up
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Pagodatastic
« Reply #6 on: August 07, 2024, 10:50:36 »
Thank you
