Author Topic: Accelerator mounting help- any pics  (Read 1035 times)
Ahealey12
  • USA, TX, San Antonio
« on: July 27, 2024, 18:23:32 »
So transmission has had issues for years and my grandma said my step grandfather had had floor board replaced under the driver side at one point. Doing all the tests today linkage does not move and does ever hit 60psi as well. Test the continuity of the pedal switch and cone to find out they never mounted the accelerator pedal (pic).
Anyone have pics to show me where to mount it once i get the part? What part actually cones in contact to the switch under it?
1967 230sl auto
1967 Chevelle ls swap
1968 bronco ls swap project
2022 zl1 Camaro
2021 Range Rover velar daily family car
dirkbalter
  • USA, CA, Corona
Re: Accelerator mounting help- any pics
« Reply #1 on: July 27, 2024, 19:11:48 »
I took these prior to replacing the floors. I might help.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Ahealey12
« Reply #2 on: July 27, 2024, 19:22:36 »
You the man! I already got it on order, truly appropriate this! Only thing i had found in German and wife couldn’t translate enough for me lol.
1967 230sl auto
2022 zl1 Camaro
Kevkeller
  • USA, HI, Honolulu
« Reply #3 on: July 28, 2024, 09:14:11 »
Is anyone able to take a picture of the pedal attached to that piece?  Mine has a hinge which doesn’t look anything like that piece.
Kevin
1970 280 SL
BobH
« Reply #4 on: July 28, 2024, 15:26:56 »
Have a look on here Kevin, there seems to be different part numbers for the pedals, manual and auto, and different ages of cars, but i think they all connect the same way, onto the two balls
https://www.sl113.org/forums/index.php?topic=37520.msg274295#msg274295
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Kevkeller
  • USA, HI, Honolulu
« Reply #5 on: July 31, 2024, 15:03:53 »
Thank you Bob,
Kevin
1970 280 SL
