Author Topic: acceleration link  (Read 876 times)
elode
  • France, Bourgogne, SAVOLLES
acceleration link
« on: July 28, 2024, 05:52:14 »
Hello everyone, after changing all of the ball joints of the connection and adjusting everything, I have stiffness when accelerating. When I detach the injection rod it is very flexible. When I move the injection rod alone it is also very flexible. The problem probably comes from this connecting rod. In my case the stem was bent originally. I have all the axes perfect. I tried to reverse the direction of the ball above. It's not better. Does anyone have an idea?
WRe
Re: acceleration link
« Reply #1 on: July 28, 2024, 06:46:18 »
Have you read this: https://www.sl113.org/wiki/Restricted/Linkage-tour and correct all length and orientation of the links?
...WRe
« Reply #2 on: July 28, 2024, 08:52:12 »
On my engine the rod between the cross-shaft lever and FIP is straight and it is attached on the outer part of the cross-shaft lever. Maybe if it is on the inside, like yours, it creates tensions.
« Reply #3 on: July 28, 2024, 15:00:55 »
It also appears that the rod is slightly bent, which would add tension.
« Reply #4 on: July 29, 2024, 03:08:46 »
The rod should be straight and 233mm from center of socket to center of socket. disconnect all other linkages and start there, with lever on the injection pump at its stop.
