Author Topic: Clutch Reservoir - Lower rubber hose alignment  (Read 1143 times)
miniwarmth
  • USA, IL, Olympia Fields
« on: July 29, 2024, 16:56:34 »
The black rubber connector hose from the bottom of my clutch reservoir to the rigid tube cracked. I thought i would just replace the tube but once i removed the reservoir, I see that the there is a fair bit of offset between the rigid hose and the bottom of the reservoir and perhaps why it split/cracked.
Does the OEM/original reservoir have a lower capacity to to achieve better alignment?
Nik
'64 230SL
miniwarmth
Re: Clutch Reservoir - Lower rubber hose alignment
« Reply #1 on: July 31, 2024, 16:40:52 »
Hi, possible for someone with '64 (or before they combined the reservoirs in 65) with an original reservoir snap a picture for me?
tia.
Nik
gtait
  • Canada, BC, Sooke, BC
« Reply #2 on: July 31, 2024, 22:20:53 »
Hi Nik,
Attached is a picture of my clutch reservoir.  Early 1964.
Hope this what you are after.
Gil
Gil
1964 230SL Standard
miniwarmth
« Reply #3 on: August 02, 2024, 18:12:35 »
Thanks Gil!!! That's what I needed to see/confirm. Definitely seems to line up vertically with that reservoir vs. mine.
Any recommendations on where to find an original?
« Reply #4 on: August 02, 2024, 18:34:30 »
PN A 000 295 10 83, not available. It costed about $8.
Here: https://www.niemoeller.de/en/w113/w113/B042/290/d29132-hose
miniwarmth
« Reply #5 on: August 05, 2024, 16:46:29 »
Thanks Pawel! I can get the hose just trying to source the correct reservoir that lines up properly.
« Reply #6 on: August 05, 2024, 19:31:09 »
I see, well, NLA at Mercedes, PN for 113043 with all replacements until chassis 02979:
A 000 295 01 15
A 000 295 00 15
A 000 295 08 15
A 111 290 02 15
