The 123ignition ignition completely replaces the original distributor and includes all other parts of electronic ignition. Make sure to buy the 123ignition with a vacuum connector.
However, I recommend buying the 123ignition TUNE, as this allows you to reproduce the Pagoda's ignition curve exactly.
A high-performance ignition coil should also be installed and the resistor in front of the ignition coil should be bypassed.
So far I installed about 10 123ignition and they work perfectly without any problems.
regards Alfred from Germany
