Hello all and thanks for your interest,
I did my test drive today. the engine was replaced with a 1979 280 se sedan engine, the car runs very nice and it has a lot more power than before and no noise see Steve's (my son and co owner of the car ) posting last week regarding the engine swap
https://www.sl113.org/forums/index.php?topic=38260.0i carefully remove the 2 prong connector to the kick down switch, thus this switch is no longer operable and will not effect the transmission. Thanks for the description of the location , it was very easy.
I drove the care and the shifting was very smooth and easy and peppy . if i accelerate from a stop and try to race someone on on the road all is fine , it shifts with no problem .
The problem occurs when i am going 30 miles per hour and i push the accelerator pedal and try to pass some in front of me. The transmission down shifts and the RPM goes up to about 3,800 and the car beautifully accelerates and i am successful in passing the car in front of me.
Problem is that the transmission is still in the "DOWN SHIFT MODE" ITS ALL SCREWED UP !!! you come to a stop and it acts crazy, does not shift still 3,000 rpm with very Heavy thumping sounds the car is not drive able it appears as if someone has thrown a wrench inside the transmission
To cure the Problem if you turn OFF and ON the ignition of the car then miraculously all gets better the transmission is like new again and shifts nicely , quietly at perfect speeds.
The transmission appears to downshift correctly based on the accelerator being suddenly depressed but it does not RESET back to normal until i am able to Turn On / off the care then it appears to reset back to perfect normal condition.
How does this happen
This transmission has been rebuilt about 7 years ago with very little mileage place on the car.
Is there an electrical module that may be broken that does not allow the to reset
I think you mentioned a solenoid that could cause this problem??? Also the transmission is my original one from the 69 SL and this problem we noticed as well while driving the SL 6 months ago.
I would love to try some adjustments and module replacements by a mechanic before we remove it and send it off to a transmission shop.
My mechanic really did not know that turning the car ON and Off would reset this issue and did not know what could this problem of the transmission not resetting after a "Kick Down Action".
It seems that there is something electrical or pressure being sent to transmission and it is not able to stop sending this message until all electrical is off
We truly appreciate your help and would love to know if this problem is a common one with our transmissions
Thanks Arthur and Steve
