Author Topic: Trunk (seal/weatherstrip) not closing  (Read 4934 times)
VikDasor
  • United Kingdom, England, Uxbridge
« on: August 04, 2024, 22:00:31 »
Dear All,
I have just had my car come back from a full paint job and as I have started to put her back together and I have come across an issue with the trunk seal. I test fitted (without adhesive) seal couple of times and the seal fits perfectly well and tight and sits in the channel as it should.
The issue I am having is that the trunk lid cannot be closed and if I force it down then it sits high at the back end.
The new seal I had bought was on eBay and it was advertised as old new stock and genuine MB seal. Now I am thinking It could well be aftermarket product but the quality and the way it fits is superb.
My problem is that the trunk lid is not closing and I have had no issues prior with trunk closing with the old seal in situ.
I did read some old posts on the forum from but they are more related to which adhesive to use and how to glue the seal down.
Any suggestions please.
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
Vander
  • USA, OH, Columbus
Re: Trunk (seal/weatherstrip) not closing
« Reply #1 on: August 04, 2024, 22:06:05 »
Post a picture of how the seal is installed. A lot of time people install it upside down, it should be open side up, curved to the side.
VikDasor
« Reply #2 on: August 04, 2024, 22:16:38 »
I have tried fitting the seal both ways but the problem still persists.
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
« Reply #3 on: August 05, 2024, 03:11:25 »
Take a look at these discussions and make sure that the top part of the seal is almost horizontal.
It also helps if you install the seal without glueing it on, close the trunk and let it sit for a few days/weeks until it adjusts.
https://www.sl113.org/forums/index.php?topic=14415
https://www.sl113.org/forums/index.php?topic=26270
« Reply #4 on: August 05, 2024, 03:30:43 »
I went through the same struggle. I had a seal from MB (always buy rubber at Mercedes if possible). I went through all possible trunk lid adjustments and replacing parts of lock.
Someone told me it will settle over time and the lid will be easier to close. And it did.
The edge of the seal that acts against the lid is quite soft and it gave way a bit over time. But I was sure I had a proper seal and it was glued in properly.
« Reply #5 on: August 05, 2024, 08:40:56 »
Also add rubber lubricant spray to the seal.
VikDasor
« Reply #6 on: August 05, 2024, 13:34:25 »
Thanks to all that replied.
Attached are some pictures in case I’m doing something wrong
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
VikDasor
« Reply #7 on: August 05, 2024, 13:43:07 »
For some reason the system is not allowing me to add multiple photos
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
Vander
  • USA, OH, Columbus
« Reply #8 on: August 05, 2024, 13:44:08 »
It appears to be upside down, the seal is sticking up. Take the bottom left corner, and flip it 180 degrees so it is now on the bottom right. and take the passenger side and put it on the driver side. It needs to be more concave.
VikDasor
« Reply #9 on: August 05, 2024, 13:54:24 »
I had it liked that yesterday but i was still struggling. I will do this again later as suggested and report back.
I
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
Vander
  • USA, OH, Columbus
« Reply #10 on: August 05, 2024, 14:03:34 »
I am doing mine later this week, so if you don't figure it out before then I will take some pictures.
VikDasor
« Reply #11 on: August 05, 2024, 16:51:37 »
Would this be correct installation
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
VikDasor
« Reply #12 on: August 05, 2024, 16:58:02 »
Rear of the trunk sits quiet high when the trunk is closed with some force
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #13 on: August 05, 2024, 22:02:01 »
Some years ago I replaced my original trunk seal with a MB seal. It too made my trunk close very hard. I too wondered what should I do t  ok resolve this problem. The Classic Center said to place painters tape (blue) along the seal and make the seal tip to bend downward, the. The trunk would close easy. They were correct, the trunk closed as it should. Then they said to keep the trunk closed for several weeks, which I did, the. To remove the painters tape and the tip of the seal molded into to correct position for the proper seal of the trunk.
Robert Hyatt
Williamsburg, VA.
VikDasor
« Reply #14 on: August 06, 2024, 16:38:11 »
Thanks Robert, I will certainly try that trick too.
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
lreppond
  • USA, CA, San Leandro
« Reply #15 on: August 13, 2024, 22:55:56 »
My experience was identical to Pawel and Robert.  The replacement seal was purchased from MB but when first installed I had a devil of a time closing the trunk lid.  I’d have to really slam it to get it to catch.  As time passed the rubber became slightly compressed and now the lid closes perfectly when no slamming or extra force required.  It’s also water tight which was the reason to replace it.  When closed, however, even immediately after replacing it it never stood proud as you've experienced.  If your trunk lid was removed for painting perhaps it’s slightly out of alignment now?
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
zoegrlh
« Reply #16 on: August 14, 2024, 13:15:04 »
That’s a good point Len.
Robert Hyatt
Williamsburg, VA.
VikDasor
« Reply #17 on: August 18, 2024, 21:58:58 »
Thanks Len, the trunk was removed for painting perhaps I will try to adjust that a little. Seem to having the same issues on the door seals too and they are all new genuine MB seals.
I suppose it’s going to take its time to settle.
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
« Reply #18 on: August 19, 2024, 08:19:37 »
If you had your trunk lid out for painting, you may want to pay extra attention to sealing of the emblems holes. Otherwise you will end up with water in the trunk and we will have another thread „Water in the trunk”.
There are small seals there for emblems studs, you can buy them from Mercedes.
VikDasor
« Reply #19 on: August 19, 2024, 14:32:42 »
Thanks for that Pawel, I would have missed those rings. They are now on my purchase list.
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
