Author Topic: Part number for input shaft and output shaft bearings for 4 speed Manual gearbox  (Read 1409 times)
Pinder
  • USA, NJ, Edison
I am trying to order new input and output shaft bearing for my manual gearbox but I am not sure of the part number. is Part #: 002-981-07-25-MBZ correct?
Regards
 Pinder
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
707dieseldean
  • USA, CA, Santa Rosa
69 280SL / Manual 4 speed
 904 - Lower Midnight Blue
 158 - Upper White/Grey
 145- Vellum Interior
Here, I marked all:
22, 2pcs
A 001 981 71 25 BALL BEARING, replaced with
A 004 981 42 01 CYLINDRICAL ROLLER BEARING
30, 86 1pc, 1pc
A 002 981 06 25, optional with
A 002 981 06 25
A 002 981 07 25
Go to a bearing supply operation and avoid MB. The bottom two bearings are common but the top two would probably need to be ordered.
Pinder
  • USA, NJ, Edison
Thank you for all the responses.
It’s really appreciated.  Is there a supplier anyone can recommend? I don’t have any urgency to get the parts asap. If you have the correct ones to sell please let me know and price. Or vendor.
Regards
 Pinder
Pinder
  • USA, NJ, Edison
Any recommendations where to get input shaft shims so I can cut down the end play?
Regards
 Pinder
On my drawing:
34 - A 186 262 04 51, spacer ring, available at Mercedes, ca $6
38 - A 136 262 07 52, shim, but only available size is 0.2mm, at Mercedes, 0.1mm and 0.3mm not available, ca $4
Pinder
  • USA, NJ, Edison
Thanks Pawel
The input shaft needs a bit of end play or the transmission will pop out of gear during deceleration. I used to add shims and sometimes it would work and sometimes it didn't.
 I put everything back together the way it came apart and I haven't had a problem since.
Pinder
  • USA, NJ, Edison
Ok Dan
  I think as I didnt have any shifting issues before or popping out of hear  I will go ahead and assemble as it was originally setup.
Regards
 Pinder
Sure, it makes sense. Bearings are precision made and all should be the same size within a very small tolerance. If your transmission was working correctly before you took it apart, it should still work after assembly because bearings are so well made. Make a poorly made product today and you won't last long. NTN, FAG, SKF, and others, are all high quality, dependable product.
