Author Topic: Replace brake servo 280sl  (Read 1713 times)
beauharlan
« on: August 09, 2024, 02:09:42 »
Hello, I need to replace the brake servo for my 280sl and need advice from everyone. Regarding replacing a new brake servo and a used old one, which option should you choose?
Any advice from anyone. Thank.
cfm65@me.com
  • Cape Town, South Africa
Re: Replace brake servo 280sl
« Reply #1 on: August 09, 2024, 08:42:40 »
I am quite sure any brake and clutch outfit should be able to recondition your brake servo.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
dirkbalter
  • USA, CA, Corona
« Reply #2 on: August 09, 2024, 14:38:23 »
I would have mine rebuild. Who knows what you get when you buy a used one.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: August 09, 2024, 14:59:09 »
I would second Dirk's comment. The servo in my 280 SL finally got to the point of repair or replace. I asked around and found a place in San Diego that could do the repair. They had not backlog and I could have had the unit back the next day! I opted to fit my schedule and got back to them the next week.
I even asked them to not paint the front of the unit to keep the original white paint marks and stickers in place.
Not cheap, $450, but it is the original unit, it fits, it works, and was a relatively easy job.
Make sure that you note the position of the eccentric bolt at the rear of the unit so you can put it back in at the same position.
« Last Edit: August 09, 2024, 15:23:30 by Jonny B »
« Reply #4 on: August 09, 2024, 15:10:27 »
During my restoration 20+ years ago, I inquired of Bud's Benz if they would rebuild my brake servo. "Sure!" they said. "Send it in!" So I did that. After a bit, I had not heard from them, and I called them. Then they said, "Oh, we cannot rebuild one of those". And they sent it back.
I ended up buying a new one. At that time it was not alarmingly high in price.
Now all these years later, I hear that people can have these rebuilt!
harrycovert
  • France, Midi-Pyrénées, castanet
« Reply #5 on: August 10, 2024, 15:36:07 »
I have a 250 servo that needs a new diaphragm any one know who woukd supply  one preferable in Europe?
TJMart
  • USA, NC, Matthews
« Reply #6 on: August 12, 2024, 20:09:01 »
I just had mine rebuilt. Like $400 to rebuild and new were like $800+. You know it is original!
Tony
Tony
1970 280SL, 4 Speed
George3
  • USA, CA, Grass Valley
« Reply #7 on: August 17, 2024, 19:14:27 »
Hi Tony. Where did you have that done? That's a very reasonable price.
TJMart
  • USA, NC, Matthews
« Reply #8 on: August 17, 2024, 19:31:57 »
Hello George,
White Post Restorations did mine. I had the Booster, Master cylinder and Proportioning valve all done at the same time.
https://whitepost.com/
Tony
Tony
1970 280SL, 4 Speed
« Reply #9 on: August 18, 2024, 16:13:08 »
We can rebuild your servo in the UK.
dirkbalter
  • USA, CA, Corona
« Reply #10 on: August 18, 2024, 17:26:40 »
I think we recently discusses the subject, but I can't find the post. I had my spare one rebuild locally (SoCaL). I paid $180 for rebuild, $ 60 for powder coating.
It is very important, that whoever you send it to, to protect the plastic (bakelite)  sleeve that sticks out of the booster. These brake very easy, especially during shipping. Most rebuilders will not be able to replace it.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
sandcrab59
  • USA, MA, Lunenburg
« Reply #11 on: August 19, 2024, 19:46:17 »
back in 2017,I helped Thierry Savidan in LAOS , to obtain the internal membranes or Diaphram.
He had a rebuilding kit but it did not have the internal membrames.
So thru the club I locate  Jeff at Karps power Brakes in Upland Cal. He supplied the membrames
So I sent them to LAOS. It worked and Thierry was happy.
Karps phone number is 909-985-0800
address is 66 North central ave.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
