Author Topic: Installing 1123330165 rubber bumbers problems 220Sb  (Read 3292 times)
badali
  • USA, Pa, Butler
  • 1966 230SL
« on: August 12, 2024, 19:57:45 »
I have been trying without success to install these bumpers on the front suspension.  I tried the string method with great failure.  I cannot get bumper to seat in the hole.  The one I'm currently fighting with is the passenger side rear bumper on the front suspension.  These are identical to the ones on the 230SL.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Installing 1123330165 rubber bumbers problems 220Sb
« Reply #1 on: August 15, 2024, 00:33:38 »
Still no luck at putting in these bumpers.  As frustrated as I am now I could just sell both cars.  I just can't crawl around under these cars anymore and is just not fun.  If anyone has any advice on these bumpers help me change my mind.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
AndrewB
  • United Kingdom, Channel Islands, Forest
« Reply #2 on: August 15, 2024, 08:46:50 »
Hi Brad,
Sorry to hear about the frustration you are experiencing. I have no idea of how to assist with installing these, hope some of the experienced mechanics (Joe A, Colin F, Dan C, Chuck T) will give you a few pointers so that you can get these installed and keep your lovely cars.
Andrew
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
cfm65@me.com
  • Cape Town, South Africa
« Reply #3 on: August 15, 2024, 08:54:02 »
Hi Brad,
How about “sharpening” the foot of the rubber bump stop. Carefully trim the food on a bench grinder, into an arrow head shape. Put rubber grease on the sharpened foot and put the rubber in position. Now fill the space between the rubber buffer and the suspension cradle with wooden blocks whilst holding the buffer in position and with a little tention on the string, you mentioned before.
Now jack up the suspension on that side. The rubber bump stop will now be squeezed between the wooden blocks and the suspension.
The rubber grease, pressure from above and pulling on the string, might help the foot of the rubber bump stop to slip into place.
Chris🤞🏼🤞🏼
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #4 on: August 15, 2024, 11:44:42 »
Here is the problem...  When placing it into position it keeps falling over.  If you remove the wheel the bumper will not fit in the opening.  The car must be on the weight of the suspension to fit in.  While placing the bumper in place you have to reach behind the wheel and slide it into place. Then you cannot see the hole without using a mirror and a flashlight.  If it does get over the hole you need to lift the car with a jack while keeping it in line with the hole at which time it falls over sideways and you have to start over.  I did put dish soap on it to help it slide in.  I had my wife lift and lower the car to help wedge it into place while positioning it.  I tried a glue gun by attaching a stiff piece of plastic to it to hold it in place while positioning it and it still falls over when loading the weight to push it in.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #5 on: August 15, 2024, 17:43:26 »
I bought these plyers today at harbor freight and got it put in in 5 minutes.  Of course I had 6 hours of practice at doing it wrong.  I managed to hold it in place with the lower end started in the oval slot.  Slowly jacked the car a little at a time as the control arm loaded weight and forced it in the hole.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
« Reply #6 on: August 16, 2024, 07:49:01 »
All's well that ends well, congratulations!
1972 Lancia Fulvia Coupe 1.3
