Hi mauro12 and thanks for your inquiry.
I am familiar with the website www-oldtimer--technik-eu for the rebuilder you are referring to.
There are a lot of issues with what he says on his website.
Basically he is trying to create a "new technology" to make up for the fact that he does not have Bosch test equipment and tools.
-I am by no means saying you cannot accurately test and calibrate these pumps on non-Bosch test equipment.
What I am saying is running a self-made bench with a 1kW electric motor is not new technology.
In order to control the speed of the motor you would need some sort of frequency converter.
That is not something novel or somehow more accurate, it is simply how you control an electric motor.
So lets break down his claims:
1) "Modern, frequency converter-controlled drive technology not only allows the respective test speeds to be maintained precisely, but also allows these speeds to be reached very quickly within a few milliseconds."
The maintaining of speed on a Bosch test bench is done in 3 parts:
a) A 3-phase AC motor ranging in power consumption from 4-14kW
b) The AC motor is connected directly to the pump of a hydraulic transmission
c) This drives a 2 or 4 speed transmission
The amount of mass this setup creates is like comparing a lawnmower to a freight train.
What Bosch needed to accomplish was high torque at low speeds. A 1kW electric motor directly driving an injection pump is not going to do that.
The second part of his claim is that reaching the required RPM for a given test is done very quickly.
This claim is absolute nonsense because there is no benefit or increase in accuracy in getting the test bench up to any given speed for a test measurement.
The whole point is to maintain the given speed during the 1000 strokes of the pump during the test.
Just to be clear, the pump is not tested during an acceleration of any sort.
2) "Paired with a powerful drive of over 1 kW, falsification of the measurement results due to the slower acceleration processes of older test benches can be avoided."
-As stated above, nothing is avoided because the acceleration of the bench to a test speed has zero bearing on said test at any given speed.
Also stated above, please note Bosch test benches operate at 4 to 14 times the power of his setup. To call it powerful is at a minimum a false statement.
3) "More than half a century after the development of mechanical fuel injection pumps, the number of functioning test benches is naturally very limited. Documents on their construction or the necessary test equipment are either non-existent or remain in the company archives. The reaction of the market economy to a scarce commodity is well known."
-Test benches are reasonably available, if you are in the pump business you can easily source one. Documents from Bosch are out there, he just does not have them.
Here is a link to the restoration of one of our Bosch test benches:
https://www.blackforestllc.com/taketwothesecondefep385a4) "Our modern test bench technology allows more; we are able to double the accuracy of the uniform delivery of the pump elements compared to the manufacturer's tolerance or halve the variation."
-Running a pump on a self-made bench setup powered by a frequency converter has absolutely nothing to do with the delivery accuracy.
The accuracy of uniform delivery has many factors I could go into detail on if people care, but his claim is patently false.
There are many other incorrect statements on his site but I will leave it there.
It occurred to me that for how unbelievable his cutting edge test bench is, why not even 1 photo of it?
-How does it control the cut-in and cut-off of fuel delivery?
-How does it control and maintain fuel pressure?
-How does it control and maintain test oil temperature?
-How does it create vacuum?
I hope this does not come off as combative or defensive. I have been in the exclusively Mercedes-Benz only business for over 25 years and I take it very seriously.
We have invested a ridiculous amount of time, energy, and money to do what we do.
I guess part of that requires one to "pay to play."
I await any further inquiries and/or lively discussion.
Michael
