Author Topic: 1965 230SL Wheel caps  (Read 3790 times)
Shamster
  • United Kingdom, England, Windsor
« on: August 19, 2024, 13:54:02 »
hello - new member here.
I have a 1965 230SL in red and love it. However I am looking for the correct smaller wheel hub caps in black (because I have a contrast black roof) Does anyone have a set? Mine currently has 1967 250/280 red hubcaps which I'm happy to part with when I get the original replacements sorted.
Shami
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
Re: 1965 230SL Wheel caps
« Reply #1 on: August 19, 2024, 15:10:30 »
It usually difficult to find a specific color.  If yours are in good shape, why not just get them painted black?
Lori
1968 280SL (US)
« Reply #2 on: August 19, 2024, 16:09:20 »
Or do them yourself. It is a bit tedious to mask them, but gets nice results. Or you can try to see if the SL group's stencil has been located.
If the hubcaps are in good shape, you can easily strip off the old paint.
« Reply #3 on: August 19, 2024, 16:18:42 »
I understand you have later type full rim hub caps and you are looking for dog bowl type, right?
In any case: if you are to remove paint from any hub caps, use chemical paint remover, I would not try to remove paint mechanically.
BobH
« Reply #4 on: August 19, 2024, 18:39:27 »
Hello, if Pawel is correct and you don't currently have the smaller caps, there are always plenty on ebay, you'll be very lucky to get the colour you want, so will end up having the paint them
Some in the UK at the moment
https://www.ebay.co.uk/itm/375068193850?_trkparms=amclksrc%3DITM%26aid%3D777008%26algo%3DPERSONAL.TOPIC%26ao%3D1%26asc%3D20240131095853%26meid%3D1573da1891d44f70a7c3577bfda79110%26pid%3D101949%26rk%3D1%26rkt%3D1%26itm%3D375068193850%26pmt%3D0%26noa%3D1%26pg%3D4375194%26algv%3DRecentlyViewedItemsV2WithMLRV6RankerPricelessTop30Features%26brand%3DMercedes-Benz&_trksid=p4375194.c101949.m162918&_trkparms=parentrq%3A6bec1bda1910ad98acae53efffff275e%7Cpageci%3Aca909d94-5e59-11ef-b4a3-f643ba8a4df5%7Ciid%3A1%7Cvlpname%3Avlp_homepage
There's a set in black in Germany, but these will need painting anyway, they look very tatty, and could be dented, plus postage may be excessive.  Better to find the best condition set you can and don't worry about the colour
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
VikDasor
  • United Kingdom, England, Uxbridge
« Reply #5 on: August 19, 2024, 20:21:15 »
For the 230sl you will also need the beauty rings that go around the lip of the wheels too. They are quite hard to find in good shape and condition but aftermarket in stainless steel are not too bad either.
Also check if you have the correct wheels for the dog dish bowls as there will be 3 protruding lips just above the wheel bolts where the dog dish caps fit on.
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #6 on: August 19, 2024, 20:33:51 »
Hi, Shami,
I have a couple of sets of (painted) hub caps (as opposed to the full wheel covers that I believe you have now), and also some beauty rings that I plan to sell (all used).  However, the shipping from California might be prohibitive.  You can PM me if you're interested and would like photos, etc.
          -David
-David Pease
« Reply #7 on: August 20, 2024, 09:14:37 »
I have plenty of used ones.
« Reply #8 on: August 21, 2024, 02:47:38 »
Shami,
That's your best bet.  Reach out to him.
Welcome to the Group!  Be prepared to receive lots of help.  Check back on your threads often.  Also, please consider jioning as a Full Member to get access to the Tech Manual (lots of technical details in a wiki), our printed publication Pagoda World, and its downloadable supplement Pagoda Notes.  Finally, start using the search feature when you come up with questions or have problems.  You can educate yourself a great deal and then when you do post, you'll post with a good background on your problem and will ask more pertinent questions.
