Author Topic: Flasher unit query  (Read 1967 times)
Merc_Girl
Flasher unit query
« on: August 28, 2024, 22:14:22 »
Hi eminent pagoda owners!
So, the ‘ticker’ sound of my indicator unit stopped working. A new ‘buzzer’ has been fitted, which works perfectly well apart from the sound it makes is intensely annoying! You feel that after each ‘beep’ will be followed by the words ’warning, vehicle reversing’!!!
I’m just wondering if anyone might be able to recommend a beeper that sounds more mechanical than large vehicle reversing warning!
I’ve read the tech manual and there do seem to be modern replacement flasher units, but I see these have bayonet connections rather than round. Other than cutting the wires to install a female connecting unit, is there a way to convert the spade to the MB cylindrical connections?
With thanks in advance
Katie
230SL
lpeterssen
  • USA, FL, Miami
Re: Flasher unit query
« Reply #1 on: August 29, 2024, 10:16:30 »
Dear Katy
This one wil work with minor modifications. Has also pin style terminals, just may need the repositioning of pins inside the connector bakelite to match terminals.
When installing it, just send me detailed pictures of the back of the unit to match lines.
https://www.ebay.com/itm/166853933533?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=LUvK-c-LTTq&sssrc=4429486&ssuid=xQJlZWrBRO-&var=&widget_ver=artemis&media=COPY
Best regards
L.Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
lpeterssen
  • USA, FL, Miami
« Reply #3 on: August 29, 2024, 10:22:56 »
And finally the other solution is to install a hazard relay sub harness on your w113-230 or 250 sl.
This sub harness takes over the function of the original flasher relay.  So you will not need it any more since the hazard/flasher relay performs both functions.
https://wiredoktor.com/products/mb-w113-hazard-relay-sub-harness
Best regards
L.peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
« Reply #4 on: August 29, 2024, 10:27:44 »
lpeterssen
  • USA, FL, Miami
« Reply #5 on: August 29, 2024, 10:32:09 »
Another one , new that will work
https://www.ebay.com/itm/134480835935?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=XN1IjnCQRA2&sssrc=4429486&ssuid=xQJlZWrBRO-&var=&widget_ver=artemis&media=COPY
Good brand and sold by a reputable / trusted vendor as is AUTOHAUSAZ in Arizona USA.
BEST REGARDS
L.Peterssen
www.wiredoktor.com
Merc_Girl
« Reply #6 on: August 29, 2024, 11:26:47 »
Thank you!!!
Will take a look
I’ve just remembered I may have put LED bulbs in as couldn’t see the whether dash lights were on or not! 😱🥰
230SL
« Reply #7 on: August 29, 2024, 21:05:19 »
... Other than cutting the wires to install a female connecting unit, is there a way to convert the spade to the MB cylindrical connections?
Yes.
Here is what I did, last photo shows my current version; originalists probably won't like it.  ;)
« Reply #8 on: August 30, 2024, 05:54:54 »
I'm confused.  Katie asked for "a beeper that sounds more mechanical than large vehicle reversing warning!".  In reply, she's pointed to relays.  Do the relays make the turn signal noise in the car?
BobH
« Reply #9 on: August 30, 2024, 06:47:49 »
The clicking sound is the mechanical contacts opening and closing, i'm not sure how modern "relays" recreate this sound, clearly Katie's relay has a modern bleeper/buzzer fitted, which i agree would drive you nuts
https://jalopnik.com/heres-why-your-turn-signals-make-that-clicking-noise-1793380845
If this is still available, it might be the last one, although only good for those who still have filament lamps
https://www.2040-parts.com/mercedes-bosch-turn-signal-relay-new-001-544-39-32-i1080125/
« Last Edit: August 30, 2024, 17:58:05 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #10 on: August 31, 2024, 03:18:54 »
Ok, I understand.  Are original relays NLA?
Merc_Girl
« Reply #11 on: September 12, 2024, 20:42:36 »
Ok
I have LED lights installed,. My understanding is that ‘traditional’ relays, for tungsten lamps won’t work
So I think my question may be
Does anyone know of a flasher unit, for LED lamps, that are able to make a ‘mechanical’ sound? 🙄
230SL
BobH
« Reply #12 on: September 16, 2024, 09:15:08 »
This one will work and has the authentic "click"
As with most replacements it has spade terminals, so will need to be modified and bullet type connectors soldered on
https://www.classiccarleds.co.uk/products/12v-electronic-indicator-flasher-relay-for-classic-cars-with-oe-clicking-sound?_pos=1&_sid=8df48c392&_ss=r&variant=13046209031
UK delivered RHD
Blue soft top
Blue leather
Merc_Girl
« Reply #13 on: September 16, 2024, 20:08:25 »
Thank you 🥰
230SL
Chris Long
  • USA, NJ, Morristown
« Reply #14 on: September 21, 2024, 12:52:57 »
1970 280sl 4-Speed Horizon Blue
