with our official
Pagoda SL Group logo
from our official partner.
Clutch for ZF 5 speed
Topic: Clutch for ZF 5 speed (Read 1270 times)
Essjays
Full Member
Junior Level
Australia, New South Wales, Sydney
August 30, 2024, 06:07:23 »
Hi all. my car is getting a mechanical overhaul at the shop. May do the clutch at the same time, we're not sure yet. my car is a 5 speed 230. Does anyone know about differences with the clutch? Tried looking through the manuals
1966 230SL ZF 5-Speed
2020 GLC63S AMG
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Clutch for ZF 5 speed
August 30, 2024, 06:27:40 »
No major differences. You will need to figure out which throw out bearing to use or use the same one that's on your transmission right now.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Vendor
Platinum
United Kingdom, England, Richmond
Reply #2 on:
September 01, 2024, 19:23:59 »
Indeed, I went down this rabbit hole a while back but in the end found that the clutch is the same, just the thrust bearing can differ.
Stick
www.colinferns.com
mauro12
Full Member
Gold
Italy, Sicily, Messina
Reply #3 on:
November 05, 2024, 23:48:53 »
The pressure plate is the same between all manual transmissions but the 230-250 have the spring type and the 280 has a different type .
Mauro Pisani
250sl 1967 5speed zf manual
Taleb
Associate Member
Senior
USA, NY, SPRINGFIELD GARDENS
Reply #4 on:
November 06, 2024, 14:28:54 »
safe your headache and sale me your car ...
