Author Topic: 230SL 22mm Front Sway Bay on 280SL18mm  (Read 1193 times)
Benz280
  • USA, NJ, Jersey City
« on: September 02, 2024, 18:31:55 »
I know there has been several threads re this swap.
Any definitive comments if this is a worthy upgrade?
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: 230SL 22mm Front Sway Bay on 280SL18mm
« Reply #1 on: September 02, 2024, 22:13:36 »
I put one on my car along with polyurethane bushings. It handles nicely but didn't increase the ride quality too much.
« Reply #2 on: September 04, 2024, 02:40:42 »
I Have the poly bushings for the 22mm if needed.
« Reply #3 on: September 09, 2024, 12:04:00 »
Wouldn’t your 230SL “Red Rocket” already have the larger 22mm sway bar compared to a stock 280SL?
Isn’t the larger diameter sway bar possibly offering “better handling” as opposed to ride quality?
« Reply #4 on: September 09, 2024, 17:53:07 »
Every car has history.  My sub fame was damaged so I used everything from a 250SE coupe which has the larger sway bar. The springs are different on the coupe so I had to change them and I added the sway bar bushings.
