Author Topic: help identifying a metal pipe in engine bay  (Read 1463 times)
Brandini
  • USA, WA, Seattle
« on: September 06, 2024, 23:23:49 »
I am needing some help identifying this metal pipe in the engine bay. At some point my engine was replaced with a sedan 250SE/C. I've noticed in the pictures that other 230SL's do not have this same metal pipe?
Brandon
1964 Mercedes 230SL - red
Seattle, WA
Re: help identifying a metal pipe in engine bay
« Reply #1 on: September 07, 2024, 01:08:55 »
Where is it connected at each end?  Do you have other pics?
« Reply #2 on: September 07, 2024, 05:01:48 »
That pipe routes coolant from the WRD to the throttle housing, from where it goes to the base of where the water pump is fitted to the engine block.
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
« Reply #3 on: September 07, 2024, 05:44:58 »
I think your line is not routed correctly.
My engine picture is an early 280 m130
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
« Reply #4 on: September 07, 2024, 05:57:01 »
Coolant did not circulate to the venturi in the early cars like the 230, so the plumbing was different. It only went as far as the thermostat housing on those early cars. Circulating cooling to the venturi prevented ice build-up in cold, wet winter weather.
Brandini
  • USA, WA, Seattle
« Reply #5 on: September 07, 2024, 15:03:56 »
Thanks everyone for the help...here are a couple of more pictures of the pipe.
So is this a cooling system pipe? Is it routed correctly? Again this engine came from a sedan 250 SE/C.
Brandon
Seattle, WA
Peter h
« Reply #6 on: September 07, 2024, 18:56:59 »
That's right on your engine, that's how the pipe runs to the venturi on the 250. I no longer had it in mind.
It warms up the venturi.
dirkbalter
  • USA, CA, Corona
« Reply #7 on: September 07, 2024, 20:34:04 »
Same her. 250 motor. Just routed below the injection lines.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Brandini
  • USA, WA, Seattle
« Reply #8 on: September 07, 2024, 21:19:12 »
Dirk - I like how you have it tucked away under the injection lines. I think I'll do the same.
Going to try and order a new zinc plated one though...anyone know where I can order it?
Brandon
Seattle, WA
dirkbalter
  • USA, CA, Corona
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
