Author Topic: Ignition Timing  (Read 1277 times)
colin evans
  • United Kingdom, Channel Islands, Ferndown
Ignition Timing
« on: September 08, 2024, 10:41:10 »
Hi guys, I posted this on the electrical forum a couple of days ago, but didn’t get any responses. Can anyone help please? It’s a rainy day here in the UK and the garage is calling!
I recently changed the head gasket on my 1971 280 SL (UK) with much helpful advice from this forum. During the process the ignition timing was altered (don’t ask!) and now I need to get things correctly set up. I have had a good read through the technical manuals but some of it is too technical for me. I have read the details in the Haynes manual but some posts on here seem to differ as regards the timing set up, so I just wanted to check a few things please.
I have new points and a new condenser, what should the points be set to? I have a dwell meter, is this the most accurate way to set the gap and if so what should the dwell be, I have read 30 to 35 degrees?
On to the timing, should it be set when the engine is warm? Should the vacuum pipe be connected or not? And what is the correct setting please. I read a post in the technical manual that said “set to 10 deg BTDC without vacuum; this should result in a setting of 8 deg ATDC at 800 RPM with vacuum. Rev engine to 3000 rpm (with vacuum) and adjust to 30 deg. BTDC”. Is this the correct approach for a UK 280SL?
My engine number is 130 983 20 008021 and my distributor is a Bosch 0231 116 051
Many thanks in advance for any advice.
Colin
BobH
Re: Ignition Timing
« Reply #1 on: September 08, 2024, 11:07:02 »
Hello Colin, have a read on here, it might help until someone experienced chimes in
https://www.sl113.org/wiki/Restricted/ServiceManual?action=download&upname=MB%20W113%20Maintenace%20Manual.pdf
Haven't had any proper rain here in Essex for weeks, the garden is crying out for some
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
colin evans
Re: Ignition Timing
« Reply #2 on: September 08, 2024, 11:15:19 »
Thanks Bob, that looks very handy.
You are welcome to our weather!
Re: Ignition Timing
« Reply #3 on: September 10, 2024, 07:44:27 »
Dwell angle is most definitely the best way to set the points. 39-42 degrees.
colin evans
Re: Ignition Timing
« Reply #4 on: September 10, 2024, 16:43:51 »
Thanks, now set to 40 degrees.
Regards Colin
