Author Topic: Rear End Alignment Revisited  (Read 2160 times)
Harry
  • USA, TN, Knoxville
« on: September 08, 2024, 21:33:06 »
It's been a bit long so our website recommended that I start this as a new post.  My last post has some very helpful responses on the alignment tool itself but I have a few remaining questions.
- What size tubing should be used?  (3/4" copper?)
- The question above is probably influenced by the features on the control arms that the tool has to fit over, ex. the 22 mm control arm nuts?
- Can you elaborate on that fitment?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
merrill
Re: Rear End Alignment Revisited
« Reply #1 on: September 09, 2024, 14:23:52 »
i made one out of large diameter pvc pipe 2"
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
dirkbalter
  • USA, CA, Corona
« Reply #2 on: September 09, 2024, 14:39:06 »
I made mine out of copper pipe. The Inside diameter of the pipe fits very nicely (no play) over the bolt. I gave the fixture to a friend. Not sure if it was 1/2 or 3/4, but you can measure the bolt and compare it to the ID of the tube.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Harry
« Reply #3 on: September 09, 2024, 16:53:38 »
Thanks very much!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #4 on: September 10, 2024, 07:25:46 »
I made mine of pvc pipes, but if you have the skill and patience - make it copper. I think pvc may come out too flexible.
