Author Topic: 1969 290 SL  (Read 2165 times)
hughrode
  • USA, UT, Orem
1969 290 SL
« on: September 11, 2024, 17:52:24 »
I am totally new.
I just bought a 290SL that has been in storage for almost 20 years.
Do I need special fluid for Clutch and Brake cylinders?
Specific things I should do or NOT do trying to start it after 20 years?
Would it be a 4 speed or a 5 speed?
hughrode
  • USA, UT, Orem
Re: 1969 290 SL
« Reply #1 on: September 11, 2024, 18:31:55 »
My bad:  It is a 280SL--it is a 1969 but a 280SL.
Thanks.
Re: 1969 290 SL
« Reply #2 on: September 11, 2024, 18:38:01 »
Hello and welcome. Congrats on your purchase
If it’s been sitting for a long time, clutch and brake fluids are the last of the fluids you should change.
The post linked is a very good summary of your steps… but check the engine turns (by hand) before you get too carried away.
https://www.sl113.org/forums/index.php?topic=38280.msg279701#msg279701
As for 4/5 speed. Statistically the probability is it’ll be a 4 speed.
MikeSimon
  • USA, OH, North Royalton
Re: 1969 290 SL
« Reply #3 on: September 11, 2024, 18:42:55 »
..It all depends what someone has done to the engine. If, for example, it received an oversize bore of 88mm, it could be considered a 290SL....just kidding ;D ;D
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Re: 1969 290 SL
« Reply #4 on: September 11, 2024, 19:16:06 »
That's a good thread to read, not just that one post.  And yes, always put a wrench on the front of the engine, spark plugs removed, and turn by hand in the proper direction.
Welcome to the Group!  Please try using the Search feature here, it may take some tries to get efficient at it.  But, with 20+ years of conversation recorded here, there's a wealth of knowledge at your finger tips.
