Author Topic: Silca Gel  (Read 1129 times)
Balsaeed
  • Kuwait, Al Asimah, Kuwait City
Silca Gel
« on: September 13, 2024, 11:29:40 »
Does anyone use Silca gel packs for long term car storage in the trunk or interior?
BADER
1969 280SL Dark Green
2012 Jeep JK-8 Black
2014 911 Turbo S White
MikeSimon
  • USA, OH, North Royalton
Re: Silca Gel
« Reply #1 on: September 13, 2024, 13:10:09 »
Yes, I do. I use them even for winter storage in my cars.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Re: Silca Gel
« Reply #2 on: September 13, 2024, 13:41:00 »
The first winter I stored my car at my then lake house garage in central Michigan, I picked up a couple of tubs of this silica gel that you are supposed to place in your shrink wrapped boat to absorb moisture.
The car was stored in late October. By January, I checked one of the tubs, and it was basically full of water. I decided then that this was a fool's errand, as not enough silica gel could absorb an autumn's and winter's worth of moisture in my Pagoda. So I just gave up.
Well, it's been nearly 25 years and I don't think the winter storage without silica gel has done any damage to the car.
Though it was many years ago, what I had purchased was something much like this: https://a.co/d/3reN4D6
Re: Silca Gel
« Reply #3 on: September 13, 2024, 20:41:00 »
If your car is in an enclosed space, a more effective way to control humidity is with a dehumidifier that has an external outlet.
yves
  • France, Poitou-Charentes
Re: Silca Gel
« Reply #4 on: September 14, 2024, 12:38:57 »
I live by the ocean and use a strong déshumidificator which deliver about 2/3 liters per day….🤔
It has an exterior water hose
MikeSimon
Re: Silca Gel
« Reply #5 on: September 15, 2024, 14:57:57 »
...bottom line is, so it seems, do not use silica gel... :o
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Re: Silca Gel
« Reply #6 on: September 16, 2024, 02:37:49 »
I use a relatively large amount of silica pellets in my inline air drier to remove -very small amounts of- moisture from the air line to paint gun when I spray paint a car. So it removes water, just not a lot.
zak
  • USA, NJ, Bernardsville
Re: Silca Gel
« Reply #7 on: September 16, 2024, 19:39:39 »
The garage where I park and store for winter my 113 and 107 is a concrete slab on grade set into a slope so half the garage is below grade.
It was a very humid place until I bought a residential sized portable , plug in dehumidifier with the outlet hose running to a drain.
The dehumidifier works great. I have it set at 45 humidity level and it is as dry as a bone in that garage year round.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
