Author Topic: Fuel Evaporation Valve Replacement  (Read 2976 times)
« on: September 21, 2024, 06:57:24 »
Could not find via search: is there a source of or replacement for the fuel evaporation valve?
sandcrab59
  • USA, MA, Lunenburg
Re: Fuel Evaporation Valve Replacement
« Reply #1 on: September 21, 2024, 12:21:43 »
Pawel:
Is this the valve that is on the passenger side of the trunk?
I have to check , I might have 2 of them.
Tom Mrowka
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #2 on: September 21, 2024, 14:04:25 »
Thank you Tom, but no, this is form the newest evaporation system, the one in the US cars on the driver's side, next to the big tank.
It has valves inside (unlike the small tank). It is NLA at Mercedes and I cannot spot it anywhere...
BobH
« Reply #3 on: September 21, 2024, 14:25:27 »
Buds Benz shows one, but says it may not be available, might be worth a call to them
https://budsbenz.com/catalog/230-250-280-sl/d-fuel
Have you had a look inside one, are they repairable, or is yours missing?
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
WRe
« Reply #4 on: September 21, 2024, 15:02:16 »
I think this vent valve (1154700293) belongs to US vehicles with ECS. It was also installed in other vehicles with M130 engines (W114) and others. I would check the "replace numbers".
...WRe
« Reply #5 on: September 21, 2024, 16:12:19 »
WRe, thank you, I saw this (by the way: I started with B2B already...). My friend with original late US car (the same you were helping with the shot thrust bearing) checked these numbers and most of the parts are NLA.
He says it looks like once you open it, you may not be able to have it back together tight. We know from BBB that there are valves inside and we know how it works, we may try carb cleaner, maybe it is just gummed up with old gas.
The symptom is - oil dripping from not tight connection to engine. Then he started blowing through various hoses and where it should shut off pressure - pressure goes free.
There are vsalves perfroming similar functions from pre-computer activated purge era, I though maybe someone figured which one to use.
« Reply #6 on: March 16, 2025, 17:39:27 »
We are still struggling with this valve...
If anyone has one please shout. I will post on Wanted To buy as well.
We will follow up with BUDs. We have followed up on the parts replacements: the 123 is NLA. There is also a replacement from 107 system, it is available, comes with additional parts, but we do not know how would we hook it up - maybe someone can give us a steer....
BobH
UK delivered RHD
Blue soft top
Blue leather
« Reply #8 on: March 16, 2025, 19:19:33 »
Thank you!
