Author Topic: Capacitor Next to Coil  (Read 856 times)
Harry
  • USA, TN, Knoxville
« on: September 21, 2024, 13:35:00 »
Hello all,
I am installing a 123 Distributor on my 1966 230SL and I had a question about what appears to be a large capacitor mounted on the drivers side frame rail (see in photo depicted between the coil and battery).  It is grounded from the bottom with a heavy braided cable to the engine block at the power steering reservoir mounting bolt, and is connected by a wire on the top to the positive terminal of the coil.  The Tech Manual shows a capacitor from the coil to ground and I expect that is the capacitor that I'm describing.
I also expect that this capacitor needs to remain in this position even with the 123.  Is that correct?
(I am changing the coil to one with a higher resistance in accordance with the 123 guidance from 123.)
Thanks very much,
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
BobH
Re: Capacitor Next to Coil
« Reply #1 on: September 21, 2024, 14:27:41 »
Hello Harry, this is for radio noise suppression, may no longer be required, but won't do any harm to reconnect it
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Harry
« Reply #2 on: September 21, 2024, 17:34:27 »
Thanks Bob.  I’ll definitely leave it connected.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
« Reply #3 on: September 22, 2024, 11:59:19 »
also, with a 123 you don't need the ballast resister.
Harry
« Reply #4 on: September 22, 2024, 13:46:36 »
Yep - thanks Paul!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
