Author Topic: Starting/Running problems.  (Read 5815 times)
R Binks
  • United Kingdom, England, BEDLINGTON
« on: September 24, 2024, 08:17:05 »
Good morning.
I wonder if anyone can shed some light on the running of Pagoda SL 1964.
The list below shows what we have undertaken so far but have yet to succeed.
•   Petrol tank replaced
•   The petrol pump electric pump was replaced
•   The injection pump was serviced and tested.
•   Injectors were checked, and two were replaced.
•   Distributor replaced with 1-2-3 electronic replacement distributor system
•   Distributor cap, leads and spark plugs replaced
•   The coil was replaced four times ( advised to purchase a Bosch coil 0221 119 027 or 021, but impossible to find.
•   All fuses in the fused box are checked.
•   The ballast resistor was replaced.
•   Tappets reset.
•   The fuel filter was replaced.
•   Pressure test the fuel system (good)
•   Test fuel rate ( good)
Despite our extensive efforts, the car's engine exhibits unusual behaviour. It struggles to start, but once it does, it runs great. However, after a variable period of time, anywhere between 30 seconds to 20 minutes, the engine abruptly cuts out, as if the ignition has been switched off. There's no spluttering, it just stops.
 Then, when we try to start again after waiting around 10 seconds for the fuel pump to prime, it usually starts again and does the same.
We have also noticed that disconnecting one spark plug leads and usually starts on five cylinders!
We're truly grateful for any assistance you can provide. Your expertise and guidance would be greatly appreciated.
Re: Starting/Running problems.
« Reply #1 on: September 24, 2024, 09:18:07 »
It may not be at all your issue but a few years ago, my 280SL would randomly cut out while driving. I found the cause to be one of the two small wires that connect to the coil to provide its signal had a slightly loose crimp connection (I made that faulty connection myself at some point) so although it seemed to be connected, it wasn't connected 'enough'. Re-crimped and soldered the connection and it's been fine since. My point being that although you replaced many 'usual suspects' components, the fault could well be in the wiring/connections/grounds and could be very hard to detect if it is a partial break inside wire insulation. Given what you describe, this is where I would focus my next efforts if this were my car. Best of luck, I am sure others will chime in as well with their thoughts.
1972 Lancia Fulvia Coupe 1.3
R Binks
« Reply #2 on: September 24, 2024, 09:34:27 »
Many thanks for the advice, we have cleaned all the earths and connections  and still have the same problem! it has us baffled.
« Reply #3 on: September 24, 2024, 10:01:18 »
The ignition switch itself?
BobH
« Reply #4 on: September 24, 2024, 10:09:11 »
It looks like you need to work through everything and rule them out, electrics, fuel etc.  Have a read through the technical manual above left, everything you need will be in here
This is a good starting point, but you'll need to register as a full member to access these pages
https://www.sl113.org/wiki/Restricted/Engine-starting-aid-tour
There's also write ups on 123 ignition (I understood the ballast resistor needs to be linked out?), correct replacement fuel pump and mounting height, timing, injection system and pump, starting aids, ignition switch, etc etc
Good luck and please feed back what you find and any more questions
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
R Binks
« Reply #5 on: September 24, 2024, 10:31:14 »
Thanks, will definitely look into the switch.
R Binks
« Reply #6 on: September 24, 2024, 10:43:49 »
Many thanks for the advice sounds like a good plan of action, hopefully report back with a positive outcome.
ctaylor738
  • USA, VA, Falls Church
« Reply #7 on: September 24, 2024, 12:05:53 »
Suggest:
Ground the 123 using the threaded hole on the bottom of the housing.
When trying to re-start, connect a timing light to see if there is spark while cranking.
Immediately after the engine dies, run a fuel volume test.
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
« Reply #8 on: September 24, 2024, 13:04:46 »
CT
Fuel volume test. I am not a mechanic, just went through a lot of similar issues with the help of Forum here.
One if the key learnings I took away from it is that erratic engine work and starting difficulties (particularly warm starting) are very often result of clogged fuel system. And fuel volume test (measuring flow at the end of return line) is a very simple test that can tell a lot. Close to 1 liter in 15 seconds, not less than 0.6 - 0.7 liter in 15 seconds may tell you if fuel goes through the system or the engine is starving.
clunker
  • USA, NJ, Chatham
« Reply #9 on: September 24, 2024, 14:45:08 »
"•   The ballast resistor was replaced."
If you installed 123ignition the ballast resistor is no longer used - it should be bypassed, with the wire from the ignition (from contact 15 on ignition switch) going direct to the coil. If you still have that in series that may be an issue.
I second adding the earthing strap to the M5 hole on the bottom of the distributor.
I also could not source the Bosch coils (was looking for red) - I used a Pertronix 40011 1.5ohm successfully.
Also, you note it cuts out immediately as if shut off, no stuttering to a halt - may this not suggest it an ignition / electrical connection issue rather than a fuel issue?
« Last Edit: September 24, 2024, 15:32:51 by clunker »
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
R Binks
« Reply #10 on: September 24, 2024, 15:17:03 »
Thanks for the information.
R Binks
« Reply #11 on: September 24, 2024, 15:17:37 »
Cheers, i will look into that.
R Binks
« Reply #12 on: September 24, 2024, 15:37:11 »
We are definitely thinking that it is most likely an ignition / electrical connection issue, and we haven’t  bypassed the ballast resistor, so we will look into that 1st plus the earth on the distributor. Many thanks
« Reply #13 on: September 25, 2024, 02:11:27 »
Which electric pump and which coil did you use?
As Cees said, just because the wire clamp is tight on the post, it doesn't mean it's tight to the actual wire.  My Jeep had that problem with a main + battery cable.  Previous owner connected extra accessories there and put it in nice heat shrink wrap.  I couldn't physically see the disconnect, cable was tight to the battery post.
franjo_66
  • Australia, NSW, Point Piper
« Reply #14 on: September 25, 2024, 03:54:33 »
i had the same exact issue and once it was sorted it runs like a champ
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
R Binks
« Reply #15 on: September 25, 2024, 10:33:20 »
Good morning,
Many thanks for replying.
We have fitted two Cambiare VE 520004 ignition coils and currently have fitted a Magneti Marelli BK 2 ignition coil.
The fuel pump we have fitted is a Bosch 0580 464 200 which we were advise to use.
We are looking into all the suggestion to try and find a solution.
Vander
  • USA, OH, Columbus
« Reply #16 on: September 25, 2024, 11:44:45 »
The fuel pump you mentioned is not for a Pagoda and is a high pressure pump. Your car would have originally come with 0442200007, although when replacing almost all early W113 owners switch to the Bosch short style pump found on the later 280SL.  Bosch Part # 0442201002
Pinder
  • USA, NJ, Edison
« Reply #17 on: September 25, 2024, 14:39:13 »
for 123 ignition. bypass the ballast resistor.   Also check the ground connection from Battey to frame. (I had this problem where car would randomly die).
I have sucessfully used the following fuel pump as a backup. its about the correct PSI.  Carter Fuel Systems Electrical Fuel Pump Automotive Replacement 12V (P4601HP)
https://www.amazon.com/gp/product/B000CIU8I4/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Pinder
  • USA, NJ, Edison
« Reply #18 on: September 25, 2024, 14:42:01 »
also make sure the engine/ transmission is grounded by the copper cable to the body of the car properly
« Reply #19 on: September 25, 2024, 21:21:08 »
I've run my 123 ignition with and without ballast resistor for extended periods and noted no perceptible difference. I finally went without as per 123 mfg instructions but I don't think this can be your issue.
« Reply #20 on: September 25, 2024, 22:13:52 »
R Binks,
I am glad you found our forum and welcome to the Group.  You have done quite a lot of work, replacing many parts.  Was this all in an effort to solve this one problem?  I hope you're working with a well respected mechanic with reasonable experience in 1960's Mercedes.  Regardless, I'm sure our members can guide you to a resolution.  The problem should be electrical, as we all seem to agree on.  The ignition switch to the coil, it could be anything along that path.  Troubleshoot with a multimeter, giggling wires, looking for poor connections.  How is the wiring in general?  Still factory original and correct?  Or, has a restorer been at work, or someone modifying for a car alarm, big stereo system, or other accessories?  Have mice been at work?
R Binks
« Reply #21 on: September 29, 2024, 08:27:52 »
Good morning,
Sorry for not acknowledging your posts. We have been busy reviewing the list of explanations and are still processing them one step at a time.
Thus far from the list, we have cleaned all the earths, changed the coil and bypassed the ballast resistor ( no difference still cuts out), but the spark at the plug seems more robust; we added an earthing strap to the bottom of the distributor.
We undertook a fuel flow test on the return line and obtained 1 litre in 15 seconds, which is well within the expected parameters.
Charles mentioned bypassing the wire from the ignition (from contact 15 on the ignition switch) and going directly to the coil, which we plan to look into.
Many thanks for your responses. It is much appreciated, and any other advice would be valued.
I think the next step is to check the wiring!!
We're genuinely grateful for the assistance you have provided
and will keep you updated.
Kevin
clunker
  • USA, NJ, Chatham
« Reply #22 on: September 29, 2024, 13:54:29 »
if you have bypassed  the ballast (connect wire to coil to 'other side' of ballast resistor, same side as ignition supply wire) then you have accomplished the bypass - nothing further to improve there. Checking cabling /contacts for fault/looseness seems a best bet.
I also note that with this sudden cutoff happening at some unfixed point after successfully starting, something may have warmed up/ become active such as a temp sensor etc - check cold start / WRM etc circuits as well, or any extra temp sensors your set up may have - they may somehow short when heated up.
Charles
clunker
  • USA, NJ, Chatham
« Reply #23 on: September 30, 2024, 22:44:12 »
Also, another thread in electrical forum gave me a thought - do you have any radio interference capacitors still connected in the ignition system circuits? If one fails when getting charged up (at inconsistent intervals) then a failure mode could possibly cause a short in the ignition system…
Charles
« Reply #24 on: October 01, 2024, 02:04:35 »
I don't see that you did a fuel pressure measurement only the volume test?
