Author Topic: Sunvisor missing peace  (Read 3497 times)
Hamid Turbo
  • USA, CA, Los Angeles, Los Angeles
« on: September 26, 2024, 00:29:31 »
Hello all,
Does anyone knows how can I find and add this missing part where it sits on clip holder?
Really appreciate it
cfm65@me.com
  • Cape Town, South Africa
Re: Sunvisor missing peace
« Reply #1 on: September 26, 2024, 13:45:27 »
Hi Hamid,
If I remember correctly there were two different types of sun visors.  Mine has a plastic, shaped like a little buckle. I think yours have about a 3mm bar across the gap and functions like a small hinge which clips into a plastic part screwed onto the top of the windscreen surround.
You could start with a similar sized rod or bar, about an inch or so long and see if you could slide it into the bracket situated in the gap. The bracket is not clearly visible. It is part of the wire frame of the sun visor and slightly hidden by the upholstery.
Googling around the internet, might give a an idea of the part you are looking for.
Good luck.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: September 26, 2024, 15:19:52 »
I am not sure which part you mean. The entire hinge? If so, they are available in SLS:
https://www.sls-hh-shop.de/de/mercedes-230-280sl-w113/81-spiegel-sonnenblenden-anbauteile-ausstattung
Hamid Turbo
« Reply #3 on: September 26, 2024, 16:28:24 »
Hi Hamid,
Good luck.
Chris
Hi Chris,
Thanks for your kind reply,
it looks like a hard plastic tube connecting two metal sides of the frame and sits on the clip on top surround.
a friend tells me to search on toy stores,
i would let you know if found,
cheers
Hamid Turbo
« Reply #4 on: September 26, 2024, 16:37:02 »
Hi Pawel,
its a peace of hard plastic tube which sits on the clip at top windshield surround.
looks like you need to have put it on two sides metal parts of the frame and heat it.
they dont sell anywhere and i must search to find the material.
thanks brother
GM
  • USA, CA, San Pedro
« Reply #5 on: September 26, 2024, 16:41:31 »
Here are the guts
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
cfm65@me.com
« Reply #6 on: September 26, 2024, 16:51:58 »
There we go, thanks Gary.
Hamid, Gary’s picture will give you a much better idea of what you are working with.
The 3 mm pin is held in position by the metal ”cage” and will acts as a hinge pin. Mine is a slightly different design so I can’t really help you any further, except. Measure holes in the bracket, my guess was about 3mm. Make yourself a pin that fits snugly into the bracket and it should work fine.
Good luck
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
Hamid Turbo
« Reply #7 on: September 26, 2024, 17:00:43 »
Here are the guts
AWESOME,
spent many hours last night to find this picture lol
Thank you so much, now i have some clue,
cheers
Hamid Turbo
« Reply #8 on: September 26, 2024, 17:12:04 »
Good luck
Chris
Cape Town
Chris,
It helps a lot,
now i need to find the material,
Thank you for your kind help,
Cheers
GM
« Reply #9 on: September 26, 2024, 17:15:48 »
Note - the photos are from a '71 280SL
Earlier ones may be different?
Hamid - the Tech Manual has instructions on how to rebuild sun visors - worth the $30 membership fee! 8)
Gary
1971 280SL - Sold
Black MB Tex
Hamid Turbo
« Reply #10 on: September 26, 2024, 17:39:38 »
mine is 1970, i think its same,
you are right and i would get membership absolutely,
thanks brother
