Author Topic: Horn pad center  (Read 3012 times)
Brennie
Horn pad center
« on: September 27, 2024, 11:22:11 »
Hi
Can you tell me if the center of my horn pad pops out? I don’t want to try and damage it.. 280SL..
Thank you
Pinder
  • USA, NJ, Edison
Re: Horn pad center
« Reply #1 on: September 27, 2024, 12:23:16 »
It’s glued in place. If you pop it off it likely will also remove part of the finish on the back and it could get ruined. This is for the original ones. If it’s a reproduction maybe it pops off.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Brennie
Re: Horn pad center
« Reply #2 on: September 27, 2024, 13:02:15 »
Thank you..
It’s an original..
it has turned yellowish over the years.. attempting to get it back to ivory..
I’ll mask it I think…
Pinder
  • USA, NJ, Edison
Re: Horn pad center
« Reply #3 on: September 27, 2024, 14:34:05 »
best to mask else you may end up having to replace the center.
Brennie
Re: Horn pad center
« Reply #4 on: September 27, 2024, 15:02:52 »
Thank you…
Already done…
Now for the hard part..
