Author Topic: Weak stater or battery ?  (Read 1193 times)
mauro12
  • Italy, Sicily, Messina
« on: October 02, 2024, 08:23:38 »
Hello guys , I’ve realized that when the car is very warm , after a long drive in motorway for example , if I shut off and turn on immediately, the starter motor is slowlier than normal ( the revolution of the start ) . This doesn’t happen when the car is cold . Any ideas ? Is not an hot start issue fuel related but I believe it depends on the starter or battery .
Any help is appreciated. Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Re: Weak stater or battery ?
« Reply #1 on: October 03, 2024, 01:16:50 »
Check the battery first. It can also be the starter at fault. You can replace or recondition yours, use a later Pagoda starter which has 0.4 more horsepower or use a new gear reduction starter which also has more horsepower. How is your oil pressure? Failing engine bearings will sometimes bind when hot.
Pinder
  • USA, NJ, Edison
« Reply #2 on: October 03, 2024, 11:46:36 »
I had a similar problem with my 1968 Cadillac eldorado. I replaced battery and new starter, and it still did the same thing slow starter turning and sometimes not at all until engine cooled down.
 I ended up putting in new wiring from battery to starter and from ground to engine block. During this process I discovered the fat positive wiring had almost melted somehow due to sparking at the starter motor (loose connection) where only a few strands were connected. replacing all the wiring (for to the starter) resolved the problem. (not saying this is the case but check for loose or damaged wiring). as the wiring gets hot its resistance goes up which causes the voltage drop to the starter making it not turn enough.
Regards
 Pinder
« Last Edit: October 03, 2024, 11:50:56 by Pinder »
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
ejboyd5
  • Southold, NY
« Reply #3 on: October 03, 2024, 12:05:48 »
Why not install a simple relay in the starter circuit:  Not only will this assure that full voltage is reaching the starter motor, it will considerably reduce the stress placed on the ignition switch and the old wiring of the original ignition circuit.
Pinder
  • USA, NJ, Edison
« Reply #4 on: October 03, 2024, 15:21:58 »
in the diagram above, if the fat red cable going to the battery is damaged (i.e parts of it thinner or nut is loose at battery or starter) it can get affected when it gets hot from surrounding heat. As a test, you could try running a new cable from battery to starterand see if it resolves the problem, before replacing starter or battery.
mauro12
« Reply #5 on: October 05, 2024, 08:10:45 »
The oil pressure is perfect . 3 bar cold and never less than 2 bar with very warm engine . I guess is mostly electrical issue , very noticeable in summer with very warm climate . How is possible that a very warm engine gives stress to the starter motor ?
Battery is also new , 1 year old . I believe is mostly an electrical issue but like I said , only when the engine is really warm . The starter motor is still the original one from 1967. Never had any issues with it .
Mauro Pisani
Richard S
  • USA, WA, Anacortes
« Reply #6 on: October 05, 2024, 14:56:43 »
Had a very similar problem many years ago.  Almost impossible to get the starter to turn over when the engine was hot.  Worked just fine when cold.  Started looking for hills to park on for rolling starts.  Finally discovered that the starter motor bearing was bad and would seize when the engine was hot.  Replacing the starter was less expensive than rebuilding the existing starter.
Richard
250SL RHD
Midnight Blue
Pinder
  • USA, NJ, Edison
mauro12
« Reply #8 on: October 05, 2024, 21:09:16 »
What is the best starter for our pagoda ? Could you post some links ? Thank you
Mauro Pisani
Vander
  • USA, OH, Columbus
« Reply #9 on: October 05, 2024, 21:46:47 »
Bosch SR59X
mauro12
« Reply #10 on: October 06, 2024, 14:50:25 »
Is available somewhere ?
Mauro Pisani
707dieseldean
  • USA, CA, Santa Rosa
69 280SL / Manual 4 speed
 904 - Lower Midnight Blue
 158 - Upper White/Grey
 145- Vellum Interior
