Author Topic: Spark Plug Wires  (Read 4363 times)
Harry
  • USA, TN, Knoxville
Spark Plug Wires
« on: October 04, 2024, 02:33:27 »
Hello.
1966 230SL.  While installing a 123 in this car (great results so far), I realized that I could tidy up the engine bay a bit by shortening several of my spark plug wires.  I have (what I would call) the old style with the metal shroud at the plug and the typical fitting for the coil.  Does anyone know whether these can be shortened, and if so how to do that?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Spark Plug Wires
« Reply #1 on: October 04, 2024, 03:52:16 »
I believe you simply remove the spark plug shroud, snip the wire, and reattach the shroud.  Others can confirm if I'm correct or crazy.
Post a couple pictures of your wires and we'll let you know if they're too long.  I don't recall people having this problem before.
Harry
« Reply #2 on: October 04, 2024, 15:26:10 »
Hi Rodd, and thanks for the help.  I'll look into it further based on your thoughts.  But the wires are just too long.  I'm not after a a highly "accurate" level car, just one that is a very nice and reliable driver.  Including the engine bay!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #3 on: October 04, 2024, 16:17:01 »
The wires are screwed into the shroud. Don't just snip the wires. There is a small screw inside the shroud, so just like unscrewing any ordinary screw, unscrew the wire and then figure out the amount needed to be cut, and screw the wire back in.
Harry
« Reply #4 on: October 04, 2024, 23:28:17 »
Excellent - thanks again all!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
