Author Topic: undercarriage product recommendations?  (Read 4289 times)
Brandini
  • USA, WA, Seattle
« on: October 06, 2024, 16:09:34 »
I've recently replaced the floor pans in my car and have applied seam sealer. Is there a roll on or spray undercoating product that is recommended?
Thanks in advance - Brandon
Brandon
1964 Mercedes 230SL
Seattle, WA
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: undercarriage product recommendations?
« Reply #1 on: October 08, 2024, 16:24:42 »
A tar base product. Any auto shop should have a spray can of this.
Robert Hyatt
Williamsburg, VA.
« Reply #2 on: October 09, 2024, 14:21:04 »
You'll have to do it all at once and throw out the can. Once you first start spraying, either finish the can or toss it, it will clog!
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #3 on: October 09, 2024, 16:43:52 »
Get a product that is paintable incase you ever plan on painting parts that were sprayed.  Some of the products out there are non paintable and even masking tape won't stick to it.
Go to a place like NAPA rather than a Walmart or Target for the product.  Make sure you mask where you don't want it as it goes everywhere when spraying.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
dirkbalter
  • USA, CA, Corona
« Reply #4 on: October 09, 2024, 17:40:24 »
I agree with above. Don't just roll some cheap tar on it. It should be paintable and somewhat duplicate the original texture. I used, U-POL Gravitex Plus HS Stone Chip Protector, and liked it a lot.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Duncan200
« Reply #5 on: October 09, 2024, 21:41:37 »
This is what I used.
https://www.henkel-adhesives.com/au/en/product/protective-coatings/teroson_sb_s30000.html
You need a compressor and they usually sell it with a bespoke application gun.
Goes on like the original stoneguard and can be painted over. Comes in 2 or 3 colours I think.
Doug
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Brandini
  • USA, WA, Seattle
« Reply #6 on: October 10, 2024, 14:23:19 »
Thank you everyone for the recommendations!
Brandon
1964 Mercedes 230SL
Seattle, WA
Brandini
  • USA, WA, Seattle
« Reply #7 on: October 10, 2024, 18:32:57 »
If I did paint the undercarriage of the car in the future what paint sheen is typically used?
Brandon
1964 Mercedes 230SL
Seattle, WA
dirkbalter
  • USA, CA, Corona
« Reply #8 on: October 10, 2024, 21:33:14 »
It should be the car color. The undercarriage was not properly painted, it was more of an overspray coming from when the body was painted.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
AndrewB
  • United Kingdom, Channel Islands, Forest
« Reply #9 on: October 11, 2024, 11:53:48 »
As I understand it, the factory sprayed on a light cream coloured paint under the car. When the body was sprayed, there would be overspray from the body on the sections underneath closest to the edges, but for the strictly correct factory look, you should use the non body paint underbody colour
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
dennismeyer
  • USA, IL, granite city
  • 16189108597
« Reply #10 on: October 14, 2024, 14:38:17 »
Thanks for the post ------- may I ask some additional questions?
My car has not been sealed underneath..... I'm guessing that i should. Any comments that might help me get it done correctly?
Also, the car needs a good detailing...... are there better leather treatment products? better - new products that you can recommend for the wash wax? engine and undercarriage cleaning?  Best, dennis meyer
« Reply #11 on: October 15, 2024, 02:59:42 »
Dry ice is the hot thing now for engine and undercarriage.  Use the Forum's search feature.
Brandini
  • USA, WA, Seattle
« Reply #12 on: October 15, 2024, 20:32:23 »
I would love to have dry ice done on my undercarriage but when I receive quotes of $2K or more its hard to justify.
Brandon
1964 Mercedes 230SL
Seattle, WA
