Author Topic: FS Getrag 5 sp 265/6  (Read 936 times)
erickmarciano
  • Canada, Quebec, montreal
« on: October 08, 2024, 16:23:57 »
Hi guys selling my getrag 265/6 over drive with the correct speedo drive
Transmission was resealed and fixed the common selector shaft leak with a better seal
All seals new
Had it as a spare for my e30 m3 and added the speedo drive
1200 USd plus shipping from update NY
It also comes with the shifter parts from bmw needed for the conversion
« Last Edit: October 09, 2024, 00:51:16 by erickmarciano »
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
erickmarciano
Re: FS Getrag 5 sp 265/6
« Reply #1 on: October 12, 2024, 15:41:28 »
price lowered to 1100 USD
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
cfm65@me.com
  • Mossel Bay, South Africa
« Reply #2 on: October 12, 2024, 16:50:50 »
Come on, guys.
Unless you have a concourse, numbers Pagoda, this is the best mod, ever!
As mentioned before, I installed one in my Automatic 250SL and loving it. I kept the auto transmission for the next custodian of my Pagoda, but I will never put it back.
The swap is not rocket science. I made up the parts and I am truly happy with the conversion.
This 5 speed Getrag is bullet proof and a pleasure to drive. I have a spare, which I am contemplating installing in my E Type. Unfortunately, I already have a 2.88 diff installed.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
erickmarciano
« Reply #3 on: October 13, 2024, 23:46:03 »
Thanks Chris
Did you do the mechanical or electronic speedo drive ?
This one has the mechanical internals
I should sell the gears separately lol
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
cfm65@me.com
« Reply #4 on: October 14, 2024, 08:27:56 »
Hi Eric,
As far as I am aware, the Getrag 265/6 were all cable driven speedos. BUT I might be mistaken, though.
I went to my local cable guy, who fitted a used, end piece of a BMW cable to my existing Mercedes cable. Keep in mind that there are many manufacturers that use Getrag transmissions. The correct fitting is, out there.
Remove the speedo cable from your car and take it, as well as the Getrag transmission to your local cable guy.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
erickmarciano
« Reply #5 on: October 14, 2024, 15:32:03 »
The e30 m3 has electronic speedo getting signal from the diff
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #6 on: October 14, 2024, 18:08:32 »
Hi Eric,
Regards
Chris
Plenty, if not most of the ones available lately, lack the mechanical drive for the speedo. BMW used to sell them as a seperate part years ago but all the opnes I've done recently have had to have an electronic speedo drive fitted.
