Author Topic: Wipers Arm and Blade  (Read 1099 times)
Balsaeed
  • Kuwait, Al Asimah, Kuwait City
« on: October 17, 2024, 21:54:31 »
This wiper arm and blade holder came with my 1969  to 280SL is it Original?
I have been reading old posts but no one seems to be sure of whats right
BADER
1969 280SL Dark Green
2012 Jeep JK-8 Black
2014 911 Turbo S White
Balsaeed
Re: Wipers Arm and Blade
« Reply #1 on: October 17, 2024, 23:07:37 »
I found these and wasn’t sure if they are correct
BADER
BobH
« Reply #2 on: October 18, 2024, 17:47:01 »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Balsaeed
« Reply #3 on: October 18, 2024, 18:29:38 »
I went through these notes but if you look at the Bosch wiped picture i posted it say 230 / 250 / 280 SL
But the length is 26 cm (10.2 inch)
BADER
BobH
« Reply #4 on: October 18, 2024, 20:03:03 »
The blades should be 305mm on all W113's, so the ones you've pictured are not correct
UK delivered RHD
Blue soft top
Blue leather
Balsaeed
« Reply #5 on: October 20, 2024, 22:59:19 »
Are the wiper arms i posted correct?
And does anyone have pair a semi satin 12 inch wiper blade for sale?
BADER
DavidAPease
  • USA, CA, Chico
« Reply #6 on: October 21, 2024, 01:07:31 »
In my experience, as Bob said, all W113s were shipped with 12-inch/305 mm blades.  However, also in my personal experience, the 13-inch/330 mm ones (originally used on W111s and W112s) work fine (maybe better than stock, as they clear a little more of the windshield).  The problem I have is finding replacement rubber for the 330mm ones (in the correct width for my bright metal blade holders).
            -David
-David Pease
« Reply #7 on: October 21, 2024, 05:49:14 »
I bought (ages ago and can’t remember where from) the blade rubber in ~70cm lengths that can be cut to fit. Just re-use the metal parts
BobH
« Reply #8 on: October 21, 2024, 09:14:49 »
Your wipers are Bosch, and are the correct length, so no reason to think they're not original?  I can't compare them with mine as my car is a 230, perhaps someone with the same year car as yours can confirm
Why not just try and get the rubber, have a look on here for the profile, should be easy enough to source
https://www.sl113.org/wiki/ChassisBody/Wipers
UK delivered RHD
Blue soft top
Blue leather
« Reply #9 on: October 21, 2024, 12:56:59 »
…The problem I have is finding replacement rubber for the 330mm ones (in the correct width for my bright metal blade holders).
This has been a common issue. I posted my solution on a similar thread not too long ago. This was my solution:
4 Pack Windshield Wiper Blades... https://www.amazon.com/dp/B0BZBZ3KHK?ref=ppx_pop_mob_ap_share
Worked perfectly on my 280SL. If not the correct size, maybe there are different sizes available. Perhaps cannibalizing the correct size off of incorrect complete blades is necessary but should not be a costly or difficult task.
DavidAPease
  • USA, CA, Chico
« Reply #10 on: October 21, 2024, 19:55:54 »
Hi, Michael,
I was so excited by earlier posts that suggested buying "bulk" refills that I ordered some refills without checking first.
Unfortunately, my holders are 10mm wide, not 6.    :-[
(Perhaps because they're the earlier "bright" ones, not the later matte ones?)
            -David
-David Pease
« Reply #11 on: October 21, 2024, 21:10:08 »
Hi, Michael,
            -David
I bet you can find ones like this, perhaps as fully assembled, and then just take them apart and use the rubbers. Whether you find bulk rubber, cheap or fully assembled blades, perhaps a bit costlier, they are still a fraction of what they would cost if you were buying them from Mercedes-Benz… If you could buy them from Mercedes-Benz! I say keep looking! You may consider taking one of the arms or blades into a good auto parts store and scour what they have available.
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
« Reply #12 on: October 21, 2024, 21:48:40 »
I, having a '65 had "chromed" wipers and had a dickens of a time finding the rubber to replace, without spending a fortune for an entire unit, which lead me to this thought
Would there be an opportunity to "bulk buy" items for members of  common parts or would that be too involved.  Any thoughts by anyone
jb
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
Jack the Knife
  • USA, FL, Vero Beach
« Reply #13 on: October 21, 2024, 22:06:14 »
jb
I'd be interested. Would be super if the club did such things more often.
1964 230SL
2015 G550
« Reply #14 on: October 21, 2024, 22:17:52 »
All it takes is someone with initiative.
In a sense, our creation and distribution of our group’s logo as window sticker, then the grille badge, then the embroidered patches are a “group buy”. Only the grille badge was sold for somewhat less than our survey indicated; patches and window stickers are given out as part of full membership.
Along the same lines the Pagoda World books fall into the same category.
Two years ago we arranged a special discount on a group buy for Blockley tires. They sold out.
So a small number of board members do these things.
Somebody needs to find the parts first. I found them for the later style, posted the Amazon link, but at $8 delivered for a set to do two cars, hardly worth a group buy.
  • USA, NY, SOUTHOLD
« Reply #15 on: October 23, 2024, 18:58:43 »
  (bulk buy etc)
 I have a problem with the phrase "we should" so I brought it up - so
let's get some input.
Let's gauge interest and get what would be some indications/ideas/suggestions of potential "bulk buy"  items or maybe quantity discounts.  I'll bring it to the Board for agreement, and approval.
There are some, like George at AuthenticClassics who already help us out.  Maybe there are others?
jb
« Reply #16 on: October 23, 2024, 23:54:28 »
Those are suitable for a 190SL.
