Author Topic: What is this part?  (Read 669 times)
yves
  • France, Poitou-Charentes
What is this part?
« on: October 18, 2024, 19:53:16 »
I have worked in the cockpit to adjust the brake pedal after refurbishment of the brake booster. I had too much play when i pressed the pedal even after adjusting the excentric bolt in the engine bay.
I made a new rod between the pedal and the booster +5 mm length with my lathe . But i saw this plastic piece of a "ring" on the floor....!( photo below) may be  it comes from the brake switch?
I wonder where it comes from?
Any idea?
 BTW i made an error about the length of the rod .... i made it 1 cm longer than the one in   the car. I tested it in the garage : i pushed the car and it moved freely. So i decided to test on the road the pedal play. It was fine at the beginning but after a very short drive the car could not go forward ! and i stopped on the road side completely stucked !
I waited 1/2 an hour ..... and then i pushed the car freely .
I came back to the garage without braking....! quite stressing
I took out the rod , grinded 5 mm , put it back on the pedal.
And now i have a smooth brake pedal for the 3first cm of push and then a strong respons as i wanted.
And i can now adjust with the excentric bolt at the brake booster in the engine bay.
Conclusion: i am  happy tonight ! after all those mistakes
« Last Edit: October 18, 2024, 19:59:03 by yves »
BobH
« Last Edit: October 18, 2024, 20:08:48 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
yves
Re: What is this part?
« Reply #2 on: October 18, 2024, 20:19:02 »
Thank.s Bob  thats.it 👍👋🏻
rmunson
  • USA, CT, Chester
« Reply #3 on: October 23, 2024, 12:25:23 »
bushing around the brake switch which allows a soft bounce back after taking your foot off the brake.
I found a knock off to replace my broken one that looks just like yours.
R.Munson
Chester, CT  USA
rmunson
  • USA, CT, Chester
« Reply #4 on: October 23, 2024, 12:27:28 »
look familiar?
R.Munson
Chester, CT  USA
yves
« Reply #5 on: October 23, 2024, 18:54:22 »
Does the new black part fit properly ?
rmunson
  • USA, CT, Chester
« Reply #6 on: October 23, 2024, 19:18:42 »
Not perfectly.  I had trouble getting it to fit like the original but simply reversed it and put it on the end of the switch and it works fine.  No more click when taking my foot off the brake pedal.
brake light switch pedal stop found at:
 Authentic Classics, LLC
https://www.authenticclassics.com/
R.Munson
Chester, CT  USA
yves
« Reply #7 on: November 01, 2024, 12:15:25 »
Can someone tell me the dimensions of this ring? Diameter ext, int , height....!
I'll try to 3D print it and put the file on the forum....
