Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
Engine grounding
Topic: Engine grounding (Read 221 times)
Gangway
Junior Level
Engine grounding
November 05, 2024, 07:11:11 »
I have two ground straps coming off the front of the engine - both are currently disconnected. One has what looks like a big condensor attached to it. Any idea where the grounds are supposed to go and what the condensor is?
BobH
Full Member
Gold
United Kingdom, England, MALDON
Re: Engine grounding
November 05, 2024, 12:13:03 »
These sound like part of the radio noise suppression kit that could be ordered with the car
There are details and pictures in the Tech Manual, see Radio - Suppression, there are two downloads with details for 230's and 280's, but you need to register as a full member to access them
Looking again at your picture, this condenser may be associated with late 280's electronic ignition, does it look like this one?
https://www.ebay.com/itm/BOSCH-IGNITION-CONDENSER-1-237-330-198-1237330198-N-O-S-/372650540642
It depends if you've changed your ignition whether it's still required
Last Edit: November 05, 2024, 15:15:20 by BobH
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Engine grounding
